586,546 active members*
3,412 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > G0704 with 3 Phase Leeson Metric motor
Results 1 to 20 of 23
    Aug 2003
    329
    Joescnc 4x4 R&P Router, Minimill, Minilathe, CNC Foamcutter, laser cutter, Vectric Aspire. http://makermasters.com, http://themakersguide.com
    Aug 2003
    329
    Re: G0704 with 3 Phase Leeson Metric motor
    I am in the middle of installing a Leeson 3 Phase motor on my G0704 along with a Benchtop Precision Belt drive.
    This is a picture of the Belt Drive as I received it. Attachment 322742.
    Aug 2003
    329
    Attachment 322756
    Nov 2009
    4415
    Is that motor mounting plate for the D80 (or what ever frame size yours is)? It looks just like the plate for the 1100 watt. They might be the same, I dont know.
    A lazy man does it twice.
    Aug 2003
    329
    This plate is for the Metric motor not the 1100 watt motor. Larger center openind.
    Bill
    Nov 2009
    4415
    Is the bolt pattern the same?
    Aug 2003
    329
    Sorry, you have to ask BTP that one. I never saw the other motor.
    Aug 2003
    329
    I just got around to posting a video showing the benchtop precision belt drive conversion kit for three phase motor. It's not perfect (the kit) but it is well-made. Anyway I hope you enjoy the unboxing video.
    https://youtu.be/qI_kbzUeeQI
    Bill
    Jan 2012
    139
    I just want to clear the air and let everyone know that this kit was not originally designed for the D80C. The D80C motor plate is an adaptation due to repeat customer request. That is why we state on the motor plate order page that the fitment is tight and some modification might be necessary. The standard belt drive kit doesn't come with the D80C motor plate, that is by customer request.
    www.benchtopprecision.com
    | BF20/G0704 Belt Drive Kits | X2 Mini-Mill Belt Drive Kits |
    Aug 2003
    329
    I just posted a video about part of my build of the G0704.
    Bill
    Mar 2016
    89
    I just ordered the D80C motor plate from Desktop Precision, a VFD, and the Leeson D80C 1.5KW motor... I only have access to 110v so I hope for the best but the stock motor is really on the fritz. The torque is so bad that I can literally grab the spindle and it would stall. No wonder it can't do any work!
    I mean I had .75HP 3 phase motor on drill presses before and I couldn't stall them if I tried...
    Aug 2003
    329
    I think there may be some confusion over which Leeson motor I used. I used a D80C motor. It is 1 1/2HP, 3 phase. I got it from Zoro Tools. https://www.zoro.com/leeson-metric-m...2/?q=192067.30
    Bill
    Mar 2016
    89
    That's what I ordered. I figure that it would still Hama with ok torque at lower speeds but I can go fast for smaller bits if necessary.
    Aug 2003
    329
    You are going to need to add 220 for this motor to work.
    Mar 2016
    89
    I found a vfd that does 110 that is up to 1.5kw. If not I'm going to have to find an extension cord or something..
    Aug 2003
    329
    I will be interested to see how that works out. It would make the upgrade even more attractive.
    Mar 2016
    89
    I got the Chinese Huamgyan one, it's cheap but they are reported to work well. I don't see why can't it work because it should work fine with a 20a circuit
    Mar 2016
    89
    By the way does anyone know what bolt do I use for the mounting holes in a D80C motor?
    Aug 2003
    329
    They were metric bolts but I don't remember the size. Take one of the bolts from the mounting feet and try that. Then go to the hardware store to match it.
    Mar 2016
    89
    I just got the motor... I am still waiting on the VFD and the motor plate from Benchtop Precision. Not sure what to do with the stock motor and the motor plate. I don't want to just throw it out but I don't need it either.
    One question... is the aluminum motor frame inferior to say a cast iron motor frame? I can see an advantage aluminum frame has is that it conducts heat better, therefore it won't heat up as much.
    I found the mounting bolt from the feet matches the holes on the motor face... I'm guessing it's M6. I will see if I can reuse it. Removing the mounting feet didn't reduce the weight much, it's basically little pieces of aluminum that weights 200 grams at most.
  1. G0704 2 HP 3 phase spindle motor upgrade
    By CodeRage in forum Benchtop Machines
    Last Post: 07-24-2020, 10:26 PM
  2. G0704 Metric 3-Phase Motor conversion
    By Deinonychus in forum Benchtop Machines
    Last Post: 06-07-2016, 09:17 PM
  3. Metric Machinist's TM25V / G0704
    By metricmachinist in forum Benchtop Machines
    Last Post: 06-03-2015, 12:03 AM
  4. Replies: 12
    Last Post: 10-13-2009, 03:53 AM
  5. Apparent issue with SJ200 & Leeson 3ph 2HP motor
    By haysys in forum Phase Converters
    Last Post: 01-14-2008, 01:04 AM
