586,565 active members*
3,646 visitors online*
Thread: Peck Tapping
Results 1 to 9 of 9
    Mar 2012
    1570
    Peck Tapping
    Does anyone know how to peck tap on a HAAS?
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Feb 2016
    381
    Re: Peck Tapping
    No but this might be worth a look
    http://www.cnczone.com/forums/genera...d-tapping.html
    Nov 2007
    479
    Re: Peck Tapping
    Make sure you have rigid tapping parameter turned on. forget which one though, consult manual.
    1/4-20 example
    G43 G00 Z.2
    S200 M5
    G84 G98 Z-.1 R.2 F10.
    G84 G98 Z-.2 R.2 F10.
    G84 G98 Z-.3 R.2 F10.
    G80
    G00 (Next hole location)
    Feb 2008
    586
    Re: Peck Tapping
    Quote Originally Posted by djr76 View Post
    1/4-20 example
    G43 G00 Z.2
    S200 M5
    G80
    I don't think you need all that repetition, as the parameters are modal.
    G43 G00 Z.2
    S200 M5
    Z-.2
    Z-.3
    G80
    Should work, too.
    Mar 2008
    638
    Re: Peck Tapping
    Yup, Beege is right. That's how we do it when we peck tap. Works fine.
    Mar 2009
    144
    Re: Peck Tapping
    Haas just put out video on this.
    https://www.youtube.com/watch?v=yBK1MN_Q9J0
    Re: Peck Tapping
    I use ONECNCXR5 Mill Professional.
    It has pecking tapping already built into the software.
    Just pick either 2 level or 3 level peck tapping and fill in the desired peck depths and presto you have it all done for you automatically. If you look at the right side of the screens you will see where you fill in the desired pecking depths.
    John
    2007 HAAS TM-1P OneCNC XR5 Mill Pro. Shopbot PRT running Mach3 2010 Screen Set, Super PID and PMDX Electronics.Check out my Gallery on: http://[email protected]
    Jul 2014
    222
    Re: Peck Tapping
    what a stupid way to peck tap, on fanuc you just add Q3 for example, it'll do same thing as in drilling cycle.
    why can't it be done that way on haas in g84?
    Feb 2009
    311
    Re: Peck Tapping
    Quote Originally Posted by allenp View Post
    That's a good question. The Haas method seems a bit tedious.
    C|
  1. Peck Tapping
    By crandalljclj in forum MetalWork Discussion
    Last Post: 04-16-2012, 12:22 AM
  2. peck tapping
    By tobyike in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-12-2012, 07:43 PM
  3. 17-4 peck tapping
    By Delw in forum Haas Mills
    Last Post: 12-11-2010, 02:43 AM
  4. peck tapping
    By qmas99 in forum Surfcam
    Last Post: 01-17-2008, 12:26 PM
  5. Peck tapping
    By Mitsui Seiki in forum MetalWork Discussion
    Last Post: 11-28-2007, 04:30 AM
