586,655 active members*
3,881 visitors online*
IndustryArena Forum > CAM Software > Surfcam > problem with stock
Results 1 to 10 of 10
    May 2016
    3
    problem with stock
    Hello all,
    New guy here with a need for help with surfcam. Can not find an answer after searching through lots of forum posts and all.
    I am trying to program a part in surfcam for a 3 axis mill and having trouble with the stock set up.
    I create a circle at the depth that material is left from the lathe work and am having trouble with an error that says tool 1 is skipped, because nothing to cut.
    If I change the diameter of the circle a little bit smaller maybe 1/4 inch it works fine... but that wont work right when trying to cut it on the mill.
    Thanks in advance!
    AB
    May 2016
    3
    Re: problem with stock
    here is what is happening . with truemill 3 axis
    if I create a circle (stock diameter) 4.2 diameter I can get the tool path to work but unfortunately the stock is 4.5. cant seem to get it to work. It also skips a few surfaces that I need to machine.
    May 2013
    142
    I've been using Surfcam for 10 years and never gotten 3axis Trumill to work correctly. Admittedly I quit trying after getting the same error the first few times.
    Try using 2axis Trumill at each Z lvl or use Adaptive Rough.
    May 2016
    3
    for anyone that may have the same problem/ is interested..I figured out how to not get that error message. I created a circle at Z0.0 dia 4.5. I then went to create-surface-trim ( I think) and cap the circle. Then when I went to 3 axis trumill I choose the surface I made for material type (not top profile as before) and changed a few parameters and the tool path was what I wanted and it worked. Now if only the machine will read it corrrectly LOL
    I did try the adaptive rough but took too long thank you tho for replying!
    AB
    May 2013
    142
    Mind = Blown
    Jan 2012
    97
    Truemill has been unsupported since around 2010. I guess when the law suit with VoluMil was settled the owners of SurfCam (back then) lost interest in Truemill and for some strange reason, they didn't sell Truemill to Vero when Vero bought SurfCam. Truemill is a separate product that you can still get with SurfCam traditional but it is totally unsupported and you can't get any help for it, if you have kept it going you are basically paying support fees for something that you get no support for. I officially reported some major issues to SurfCam back around 2011 and have never heard a word back.
    Truemill had some great potential, far as I know (which ain't much), many of its mutli-tool step reduction roughing strategies using STL stock models are still locked up under patents and the patent holders are known to be very tenacious at tracking down and dragging patent infringers into long drawn out expensive court battles.
    Apr 2003
    637
    I agree with machinister. We stop paying maintenance because they stopped supporting what they were selling. It's as simple as that. I'm sure we were not alone.(nuts)
    Jan 2012
    97
    BTW... If you had full 5 axis Surfcam (traditional) and added the new Surfcam 2016 R1 (EVO) at that same level for free. Say Hello to your new maintenance bill of $6,300...
    May 2013
    142
    Quote Originally Posted by machinster View Post
    lol! You fell for it!
    For what its worth. Ours maintenace was gonna be $7000 for 2 seats of advanced milling, standard turning and wire. And about $8100 for 2 seats of ultimate milling, standard turning and wire. All that on top of paying for the upgrades.
    Jan 2012
    97
    LOL....
    Yes I did... Yeah, its steep but its not so bad, they told me that I can go back to just traditional and pay the same amount as in years past, so it's not like I'm not stuck with paying for it forever.
    However, I am seriously thinking about keeping EVO, I really think that it's the wave of the future... I've spent some time working with it, and there really is a lot to like about it, but as usual, some stuff there, not so much...
    So I guess the jury is still out...
  1. TL 3 Tail stock problem
    By WILDMAN2 in forum Haas Mills
    Last Post: 03-07-2016, 12:33 PM
  2. Problem with Stock Thickness
    By _Lou_ in forum GibbsCAM
    Last Post: 08-17-2015, 05:49 PM
  3. Stock Manager Problem
    By JHL in forum CamWorks
    Last Post: 11-24-2014, 01:59 PM
  4. Mastercam X4 - stl stock problem
    By wayja in forum Mastercam
    Last Post: 05-12-2013, 02:33 PM
  5. Stock Manager problem
    By Joesph Jackman in forum CamWorks
    Last Post: 12-21-2011, 04:37 AM
