Re: 3.23 KW Brushless motor as spindle.
I have converted similar motors to encoder with simulated hall effect tracks, you need to know the pole count and also carry out an alignment using a double beam 'scope.
If you short the three stator wires and turn it one rev and count the 'bumps' will tell you the number of poles.
There are quite a few analogue inpujt drives out there, AMC etc.
Al.
Albert E.
