Hi fellow Tormachers!
Well, my machine is almost 10 years old. Its an early series 1 thats been upgraded to series 3 electronics. Im happy to say that mechanically its still solid as a rock. No detectable wear on the ways, table is still in good shape. But the Y axis ballscrew may have an issue that warrants either adjustment or replacement. Since I could find no literature online about replacing the ballscrew, I thought I'd ask you guys for advice before I turn a bolt.
Have any of you done this before? Anything to keep in mind?
Should I buy a direct replacement or go for a more accurate screw via Ebay if one comes up?
And the bonus:
I have a touch probe very to the Tormach version except it has a 3.5mm "audio" jack instead of a 5 pin DIN plug compatable with the tormach aux recepticle. Is there a pinout of the Tormach female DIN aux floating around, or have any of you wired up something similar? Im sure I could locate the gnd and 5V pins but know the aux has provisions for other accessories and there may be more than one 5V on there. So which would be correct for the probe?
And as always, thanks in advance.
Cheers,
SD
