586,488 active members*
1,809 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > Step Motor Driver and Power Supply Wiring
    Dec 2006
    18
    We are nearly at the end of building process of a CNC machine. 3 PICStep v4 boards from fromorbit.com and 4-Axis BOB card from pminmo.com are built also. What is left for the final stage is the power supply
    Rather than building a custom power supply, can we use the PC power supply? The step motors are rated for 2A so I think a single PSU will be enough to drive the steppers.
    Rather than using a single power supply for all the axis and the BOB card, I am thinking about using 3 power supplies one for each axis. Would it be possible? Any tricky point that I must pay attention to?
    Jun 2003
    3312
    You would be better served by wiring 3 pc supplies 12v in series. Steppers perform at higher spped better with higher supply voltages generally.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Dec 2006
    18
    Thanks for the the quick reply pminmo.
    http://www.procooling.com/index.php?...s&disp=52&pg=1
    good link for connecting pc supplys in series
