586,950 active members*
2,778 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Double NC postprocesor
Results 1 to 9 of 9
    Apr 2016
    21
    I have an error in the program after generate NC track becouse between Helikal interpolation and circular(?) 2D interpolation I have the same value of track.
    I had changed in Helikal interpolation in postprocessor to generate radius R instead IJK becouse my machine doesnt accept IJK.
    The program pass in machine only if I remove repeating track but it's not the point to correct bugs manually.
    I had trying enhance range generating of decimal numbers but it doesnt work.
    The program lap NC code:
    N86
    N87
    N693
    N694
    N246
    N247
    I put below screenshot and NC files, postprocessor, edgecam.
    Feb 2011
    10
    Re: Double NC postprocesor
    Oct 2003
    155
    Try going into code wizard, open your post, then open drop down menu for: NC Style, G-Codes and Modality, then double click to open (Modal) & checking the boxes for (X Axis Coordinates, Y Axis Coordinates and Z Axis Coordinates) to make them MODAL.
    Might need to do the same for : (Arc Radius) check box?
    Click (Apply then OK)
    Save changes & compile before closing code wizard.
    In Edgecam...
    Go to Machining Tab: Sequence & under Instructions: right click on Sequence 1 and Regenerate.
    Go to NC Code Tab: Generate NC
    See if that works for you n your machine!
    MegaMoog
    Apr 2016
    21
    I had earlier tried to change in Modal but it didn't help.
    I have no other ideas, I have tried everything.
    Oct 2003
    155
    I used your post n modified the MODAL settings, then posted & the Double G-Code was not there when creating NC file on my computer.
    See attached files.
    Modified Post...
    Screenshots of G-code...
    O6666 modal.nc file
    MegaMoog
    Apr 2016
    21
    I tried also this way, tracks are not duplicated,but there are other bugs in NC code.
    There is no R character at G2 and G3 code, so error pops up.
    Look at the attachment, I I marked with a red line.
    Postprocessor doesn't work, becouse my friend didn't compile and didn't write I guess.
    Oct 2003
    155
    OOOPS... I missed that part, probably getting to late in the day! At least we got the double NC lines gone.
    That post still had R modal being applied.
    I have created two more posts that you can try...
    Both are (R non-modal) but one has single quadrant applied in which will create more line code, but might work also...?
    There might still be some redundancy , but take a look n give it a try.
    What machine control are you using? Fanuc or something else?
    What version Edgecam are you using? I have V2015 R2.
    Apr 2016
    21
    Quote Originally Posted by MegaMoog View Post
    Thanks for the help.
    I did not know that you can solve this problem "single quadrant."
    I use Edgecam 2014 R1 so that's why my postprocessor didn't work.
    Now I moved to Edgecam 2016 R1 and everything works as it should.
    Thanks!
    Oct 2003
    155
    AWESOME…..
    I try to give back to the cnc community…
    People have gotten me through some tough stuff here @ the ZONE…
    Glad ya got what was needed… more than happy to help…..
    Megamoog:cheers:
  1. CNC Router with Double Spindles and Double Rotary
    By WINNI-DI in forum Chinese Machines
    Last Post: 12-01-2015, 03:01 AM
  2. Postprocesor
    By Maroslav4 in forum Post Processor Files
    Last Post: 11-04-2015, 11:33 PM
  3. postprocesor variable
    By Lubos78 in forum EdgeCam
    Last Post: 06-08-2015, 10:02 AM
  4. Postprocesor vh65
    By mordock in forum Fadal
    Last Post: 05-04-2010, 02:28 AM
  5. Postprocesor
    By milwin in forum Surfcam
    Last Post: 09-16-2008, 10:15 AM
