586,551 active members*
3,326 visitors online*
Results 1 to 8 of 8
    Dec 2015
    7
    K2 CNC distance problems
    several months ago i upgraded my computer and software, i had some issues getting things up and running again and some of you FINE folks helped me out !
    I recently discovered that its not actually cutting the proper size or scale. over the course of 22" its off by 3/8", meaning if i lay a ruler down and manual jog the machine to the 22" on the ruler, the computer reads 22.375
    so I'm trying to figure out how to correct this, thought I would run it by you guys, i'm hoping its something simple. its off on all axis, X,Y and Z
    thanks for any help,suggestions or assistance.
    Feb 2007
    4553
    Post Re: K2 CNC distance problems
    Bootleg,
    I am assuming you are running Mach3 and if so the "steps per" in the motor tuning has not been set accurately.
    Mach3 has a axis calibration utility on the settings page that will correct the issue.
    There are several YouTube tutorials that explain the procedure.
    Attached are several that may help.
    https://www.youtube.com/watch?v=LRagjLewSJg
    https://www.youtube.com/watch?v=XkO5tc-jSxw
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Dec 2015
    7
    I do not have Mach 3 but the thats exactly what I am trying to fix
    Feb 2007
    4553
    Bootleg,
    What control software are you using?
    Jeff...
    Dec 2015
    7
    Kmotion 429
    Feb 2007
    4553
    Quote Originally Posted by bootleg View Post
    Kmotion 429
    Bootleg,
    You may receive a quicker response to your question if you post in the Kmotion section of the forum:
    http://www.cnczone.com/forums/dynomotion-kflop-kanalog/
    As you may already know Tom Kerekes is the Kmotion developer.
    Jeff...
    Jeff...
    Apr 2020
    5
    Please which control software are you using because i just have the same issue
    Apr 2020
    5
    oh okay thanks i just saw this
  1. retract distance and go to zero.
    By FoxCNC1 in forum Aspire
    Last Post: 02-14-2014, 07:05 PM
  2. Distance between bearings.
    By Oxyd in forum Mechanical Calculations/Engineering Design
    Last Post: 06-07-2011, 09:52 PM
  3. Linear Cut Distance
    By rescueweasel in forum Mach Plasma / Laser
    Last Post: 10-10-2010, 10:54 PM
  4. What's your max distance to encoder?
    By murphy625 in forum CNC Machine Related Electronics
    Last Post: 05-12-2005, 04:57 PM
