586,546 active members*
3,234 visitors online*
IndustryArena Forum > Mechanical Engineering > Epoxy Granite > epoxy granite sliding on epoxy granite.
Page 2 of 2 12
Results 21 to 23 of 23
  1. #21
    Jul 2018
    6406
    Re: epoxy granite sliding on epoxy granite.
    Hi Pippin here's a good read. Peter
    Attached Files Attached Files
  2. #22
    May 2022
    9
    Quote Originally Posted by peteeng View Post
    Hi Britt - Search for koehler article in the forum. The concrete guys have thrown out the graded approach. A two size mix seems to result in the best packing factor. Peter
    Agreed. This guy [1] came to the conclusion 66% sand and 33% dust makes the most stiff bar. Moving to 33% stones, 33%sand and 33% dust yielded the same results.
    [1] Epoxy granite stiffness - test and results
    https://youtu.be/gjw5juGG1g8?t=1062
  3. #23
    Jul 2018
    6406
    Hi All - Very good video. Shame he didn't use an aluminium bar as a baseline in the tests. But if we look at his chart and most laminating epoxies are 3-3.5Gpa and if his stiffness rating is based on the deflections then the EG is ~10x stiffer. ie 3.5/1.2X10= ~30Gpa which is typically what the EG guys are getting. Peter
Page 2 of 2 12
  1. Epoxy Granite Lathe
    By LazyH in forum Vertical Mill, Lathe Project Log
    Last Post: 04-02-2016, 06:48 PM
  2. A new epoxy granite CNC
    By muppy in forum Epoxy Granite
    Last Post: 07-02-2015, 11:46 AM
  3. Why is there so little going on in Epoxy Granite?
    By CaptainVee in forum Epoxy Granite
    Last Post: 06-23-2015, 03:28 AM
  4. epoxy granite
    By bebob1 in forum DIY CNC Router Table Machines
    Last Post: 10-30-2012, 11:25 AM
  5. Epoxy granite
    By slektning in forum Norwegian
    Last Post: 06-29-2011, 08:57 AM
