586,655 active members*
2,501 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Tab positioning help/advice needed!
Results 1 to 7 of 7
    Feb 2004
    1311
    I can't seem to be able to locate the tabs where I need them on a circular part. See attached screenshot. Basically, this is the left most of two parts. I would like the tabs on this part rotated 180° so the middle tabs of the two parts are connected. I tried doing the profile operation on both geometries and now have tried separating the geometries but I always get the same results. If I let BobCAD add the tabs automatically, it always orients them (3 tabs) like this. If I try to do it manually, I can't put them where I want. Holding shift-selecting does not really show me anything. Is there a technique to do what I'm trying to do? Thanks!
    Reelsmith, Angling Historian, and Author of "The Reelsmith's Primer"
    www.EclecticAngler.com | www.ReelLinesPress.com
    Jun 2008
    1838
    Re: Tab positioning help/advice needed!
    Quote Originally Posted by mhackney View Post
    Hi Michael
    See attached image below and let us know if this is what you are looking for If so then read on
    Attachment 317458
    Attachment 317456
    The tabbing defaults to the correct cartesian start and end coordinates for a circle, so the start of the circle is always at the 3.0 o`clock point and goes clockwise from there.
    So to move the tabs around you can alter the start and end points of your circles as per the attached BobCAD file I have Zipped up, look at the left hand circle by using select mode and then selecting "Entity Modify" and you will see in the Data pane the circle info with the start and finish angles of
    start 300 and end 660, works for me
    Whether this is the way BobCAD intends the tabbing system to be used I really have no idea, it may be just my oddball "workaround", however it works for me
    Hope it helps a little
    Regards
    Rob
    :rainfro: :rainfro: :rainfro:
    Feb 2004
    1311
    Yes, that is exactly what I am looking for!
    My part is a 3D geometry and when I attempt to do Entity Modify, nothing happens. Is there a trick to that or do I just need to draw separate circles and use those to cut the perimeter of the part?
    Jun 2008
    1838
    Yes, I think you will need to draw 2D circles for that but you should be able to extract the edges of the 3D circular part which will give you the 2D circles you want, give it a try
    Or upload your file and maybe someone can figure it out
    Regards
    Rob
    Feb 2004
    1311
    Yes, I was experimenting after I replied. I did Utilities->Extract Edges-> From Solid
    Interestingly, this resulted in 11 arcs. I was able to move tabs to the ends of these arcs to get the tab layout I want. Not sure why 11 arcs but the tabs look to be 120° from each other.
    Feb 2004
    1311
    Well, no they aren't 120° but they are close enough for what I am trying to do.
    Feb 2004
    1311
    So spending more time with this I've developed some "tabbing chops"! Basically, I extracted a single edge (so now I know how to use that tool) to it's own layer so I can manipulate it easier. I then used Utilities->Break->Many to divide the circle into 6 pieces (or you can specify however many you want). This then gave me locations to place the tabs at 60° increments around the circle so I was able to place them exactly where I wanted them 120° apart. This works really well and is generally useful for placing tabs. Some of the other Break options could be used to explicitly locate where to break the perimeter to get precision for other types of shapes.
  1. [ADVICE NEEDED] Z-Axis not moving - CNC builder needed
    By baodogg in forum Australia, New Zealand Club House
    Last Post: 06-03-2014, 12:42 PM
  2. Material advice and advice needed
    By kiyoukan in forum Mechanical Calculations/Engineering Design
    Last Post: 02-15-2012, 08:20 PM
  3. Advice needed.
    By tomshep in forum Benchtop Machines
    Last Post: 10-01-2008, 10:59 PM
  4. XY positioning algorithm needed
    By Tracid in forum PIC Programing / Design
    Last Post: 11-28-2006, 05:26 PM
