587,034 active members*
3,219 visitors online*
    Apr 2016
    10
    floor thickness help
    I am going to try posting this here? Im new here and looking for some advice on the thickness of a concrete floor needed. I purchased a used hurco bmc 4020 and am going to be putting this in my home garage shop. Directly after I bought the machine I called and talked to the local rigging company but they said that they do not think that my standard 4’’ thick garage floor will support the machine. The machine weighs 12,400 lbs. is any one able to answer this for me? If I have to I will hurry up and demo my garage floor to make it thicker but want to make sure it is necessary first. Any help would be greatly appreciated!
    Feb 2016
    381
    Re: floor thickness help
    A lot of variables involved 4" of concrete on a good base will support it with no problem, if all the weight is in small areas i.e corners on 2" feet then I would consider putting pads under them to spread the weight a bit 9" square 6mm steel. But unless floor was laid using substandard materials by a bunch of cowboys I cannot see any reason it would not hold it with ease
    Apr 2016
    10
    Quote Originally Posted by Louis_Cannell View Post
    thank you for the response. ill give it a shot and i will get pads just for extra caution
    Feb 2009
    6028
    If it's not reinforced with mesh or rebar, it will crack a 4", and riggers are afraid to move it in because it will be point loaded on the rollers as they move it in. Might want to think about a steel plate under the machine.
    Sent from my A3-A20FHD using Tapatalk
    Aug 2014
    29
    Quote Originally Posted by underthetire View Post
    Having a degree in concrete tech, I can tell you that reinforcement such as mesh or rebar will not keep the concrete from cracking, it will just hold the concrete together where it does crack.
    The real enemy is the vibration from the machine that will settle whatever material is underneath the concrete, and as it settles, the concrete loses support and cracks. 4in concrete does sound way too thin for a 12000lb machine.
  1. Floor Me...Floor You
    By FFWD in forum Maintenance DIY Discussion
    Last Post: 03-27-2011, 02:34 PM
  2. Pines Numbers 3&4 Benders Frame Thickness and Nose Thickness
    By morribi in forum Bending, Forging, Extrusion...
    Last Post: 02-04-2010, 04:59 AM
  3. New MA-500 on the floor
    By Shotout in forum Okuma
    Last Post: 01-26-2010, 10:12 PM
  4. New shop-Floor??
    By bdrmachine in forum MetalWork Discussion
    Last Post: 09-19-2005, 07:41 PM
  5. Shop Floor
    By cncadmin in forum Uncategorised CAM Discussion
    Last Post: 06-23-2003, 02:19 PM
