Hi everybody,
I am working on a CNC milling machine since a few months now and I would like some advice from you.
Some technical details :
- Aluminium structure,
- X axis : 220mm movement, 20mm linear rails and blocks, NEMA24 4Nm steppermotor coupled to 1605 ball screw
- Y axis : 400mm movement, 15mm linear rails and blocks, NEMA24 4Nm steppermotor coupled to 1605 ball screw
- Z axis : 140mm movement, 20mm linear rails and blocks, NEMA24 4Nm steppermotor coupled to 1605 ball screw, with counterweight into vertical column to relieve steppermotor.
- HF motor (Teknomotor C3140) 0.75Kw
Actually, I have some doubt regarding sensor to use for each homing : inductive? Mechanical? is 4Nm enough for steppermotor?
Please don't hesitate to give me your feedback ! Thanks
Some screens of it (designed with Solidworks) :
