586,974 active members*
3,561 visitors online*
Results 1 to 5 of 5
    Jan 2004
    137
    Cool the finishing pass
    I currently leave .015 material for my finishing pass. Most of my stuff gets polished, and I have been thinking about making this measurment a littlle greater. My results are pretty good, but I think I could get a better finish, thus less work on the deburring and finishing wheel. Thus saving some time...
    Can anyone tell me, what the standard/recommended amount of material being removed during a finishing pass may be?
    Also will conventional or climb milling make much of a differance in my finish pass?
    Since material may differ, let's say aluminum and steel.
    Thanks,
    Kenny
    "Plan your work; Work your plan"
    4826
    Climb mill with carbide. There's nothing wrong with .015" to finish if you want accuracy.
    What kind of controller are you running? Are you doing 3d work? What I am driving at here, is if your program consists of many short segments, then it becomes essential that your controller can read them fast enough to maintain a steady feedrate. Data starvation leads to dwell marks on the work, no matter what. The solution for that is to upgrade to a controller with plenty of lookahead. That's what I am doing
    Nov 2003
    181
    When I'm working in mastercam I usually leave about 10 thou. It's enough to be cut away but at the same time not enough to make the tool wonder. In the finish pass you have quite a bit of room anywhere from 5 to 20 or 30 above, Not sure what ideal is but I'd say your 15 is pretty close,
    Jan 2004
    137
    Thanks for your input, it is truly appreciated.
    My controller is a Fanuc 6, it seems to do well, and I normally make my segments as long as possible. Not too much 3D stuff, mostly 2D.
    Even though I use approach and depart methods, the .015 being close still gives a gouge or two for me to deal with from time to time. I figure it's due to raduis cuts in combination with cutter sharpness and speed & feed.
    Like many people, I like the automated machining aspect, it's the final deburring and polishing that's dirty and time consuming.
    Feb 2004
    813
    try arc in and out for the leadin; this will create a better finish
  1. Mass finishing and deburring strategies
    By Idle hands in forum Mass finishing equipment/media/strategies
    Last Post: 06-11-2005, 05:41 PM
  2. Empty Roughing pass
    By new2cnc in forum Mastercam
    Last Post: 05-28-2005, 02:31 PM
  3. MDF Finishing Question
    By The Wizard in forum DIY CNC Router Table Machines
    Last Post: 11-01-2004, 05:29 AM
  4. VQC Face Milling three pass
    By Ken_Shea in forum Haas Mills
    Last Post: 08-13-2003, 05:10 AM
