Hi
I would like to hear your opinion about the most suitable software to handle AT LEAST Gerber,Excellon,BMP (maybe a GCODE simulator included) and generate basic ISO G-CODE:
M03, M04, M05 Spindle CW, Spindle CCW, Spindle Stop
M08, M09 Coolant/lubricant On, Coolant/lubricant Off
M02 Program Stop
M30 Program end, rewind
M98 Subprogram call
M99 Subprogram end
M00, M01 Program stop, optional stop
G96, G97 Constant surface speed, Constant Spindle speed
G50 Maximum spindle speed
G95, G94 Feed mm per revolution, feed mm/min
G00, G01 rapid movement, Linear Interpolation (cutting in a straight line)
F Feed
S Spindle Speed
direction Coordinates X Y Z A B C U V W
The only software I found flexible enough and with a nice interface is Galaad.Anything else ?
Thanks, Nitro
