587,058 active members*
3,905 visitors online*
Results 1 to 10 of 10
    Aug 2011
    61
    E stop not letting machine run
    So, my 440 came home and is now setup. After I wired up the machine I proceed to turn it on. But the the e stop is preventing me from doing anything. I checked all the wiring and everything is secured. I reboot everything but the e stop is still preventing me to do anything. Anyone have any clues what is wrong?
    Jul 2015
    81
    Re: E stop not letting machine run
    Dumb questions here, did you twist the red button clockwise and here it click out then push the green button next to it?
    On my 1100, I reassembled the red button improperly after taking it apart to mount the box on the enclosure.
    I could not start the machine until assembling the button right.
    Aug 2011
    61
    Quote Originally Posted by oneineight View Post
    Hmmmm....i did twist the button clockwise and the e stop came assembled. I'll check to make sure everything was assembled right.
    Mar 2016
    325
    question: should the button be connected with NC or NO connectors?
    If it should be NC maybe button is broken (burnt connectors) and has some resistance.
    If NO maybe there is a short circuit inside.
    Jun 2012
    10
    I would check if there is power to the stepper drive in the cabinet(red leds if e-stopped). Does the cabinet fan come on? That uses the same 48VDC, If no DC power, I would look for a loose wire on power or neutral (give them a tug). That is most likely to be a problem that would occur from shipping.
    Jun 2008
    1082
    Sorry, non-Tormach user here, but I'd still like to throw out a couple questions/ideas in an attempt to help. If speculation-based posts annoy anyone, skip this one...
    Q: Why do you think it's the e-stop? Is PathPilot displaying a specific message, like "the e-stop button is depressed"?
    Q: Assuming this problem does appear to be originating with the physical switch, would there be an easy way to swap the NO/NC condition from within PathPilot? As best as I can recall, in Mach3, you can go into "Ports and Pins", find the e-stop pin, and switch it from NO to NC (or visa-versa). Of course, if this solves your problem, you should focus your troubleshooting on the wiring/switch. It is NOT SAFE to run the machine without a functioning e-stop switch and you should make sure the change the setting back before using the machine.
    Q: Does PathPilot have something that resembles the "Diagnostics" tab of Mach3? In other words, can nutzilla simply open a window in PathPilot and activate and deactivate the e-stop switch while watching a certain screen to see if the switch is working correctly?
    Aug 2007
    701
    Post a screen shot of the error msg on the status screen. That will help diagnose things.
    Mar 2013
    72
    I have a 770 and installed the external E-Stop, I discovered that the external E-Stop is wired NC - I think it's wired in line with the internal E-Stop. So my guess (though you have a 440) is that the E-Stop is NC while operating and goes NO when you press the Stop Button.
    Aug 2011
    61
    I called the place I purchased it from and figured it out you have to push the green button after you release the e stop and then reset on path pilot.
    Jul 2004
    1424
    Now that you mention it, I remember scratching my head the first time I powered up about that sequence.
    Tim
  1. Machine stop / Spindle Stop with a Dwell
    By yaji63 in forum Fanuc
    Last Post: 02-16-2014, 06:49 PM
  2. Replies: 3
    Last Post: 09-14-2013, 08:02 AM
  3. after 3yrs we're letting the table go
    By woodman08 in forum Hypertherm Plasma
    Last Post: 08-19-2011, 06:29 PM
  4. Replies: 2
    Last Post: 08-09-2006, 09:07 PM
