586,489 active members*
2,473 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > VF3 spindle high gear fault alarm #117 help!
Results 1 to 15 of 15
    May 2006
    4
    Question VF3 spindle high gear fault alarm #117 help!
    Can anybody shed any light on this problem for me? Any help for a quick / economical fix would be greatly appreciated!
    Mar 2005
    1498
    070110-2027 EST USA
    Fault #117 is discussed in the HAAS manual. Have you looked at the comments? If you do not have a manual, then go to the HAAS web site and down load it.
    Jul 2005
    12177
    The alarms are not in the manual files on the Haas website they are in a separate document, not easy to find if you are not used to their website. Here is the 117 alarm description:
    117 SPINDLE HIGH GEAR FAULT - Gearbox did not shift into high gear. During a change to high gear, the spindle is rotated slowly while air pressure is used to move the gears but the high gear sensor was not detected in time. Parameters 67, 70 and 75 can adjust the time-out times. Check the air pressure, the solenoids circuit breaker CB4, and the spindle drive.
    Jan 2006
    357
    This has happened to me before on a VF4 there are two solenoids on the VF4's that change the gears, if I remember correctly they are on the back of the column up near the top, also sometimes if it does not stop correctly it will kind of hang between gears. What I have done in the past is do a power up restart and it should go back into low gear. If this happened while tapping and the soleniod is bad simply use the M41(low gear over ride) until you get a new one.
    Sep 2006
    51
    There is little trick you can do.When you go to the back of the machine there is an Air regulator for air line coming in.After the regulator there are two plastick tubes.Buy some very light sawing machine oil(hardware store) , the lighest you can get and put two drops of it into the thicker line.Your piston for gear changer got stuck.After few times it should move.I had the same thing.I was running machine at hight gear for a week and then had the same problem.Run your machine at low rpm just to shift gears daily and you will be OK.
    Dec 2006
    54
    This is an old post but i have had some recent experience and thought i would share. We had the same problem on our vmc. Just wouldn't go into high gear. The owner had this problem before and repaired it. This time we went into more troubleshooting. We applied full shop air to the shift cylinder (located in the head on the side of the transmission) and it shifted into high and low with no problem. The air that is supplied to the shift cylinder goes thru a .010 hole on the manifold block the shift solenoids are mounted to. We drilled it out to .020 thinking it might help, no luck. Next we thought it might not be exhasuting one side of the cylinder when it trys to shift into high, making the cylinder fight itself. We changed the high gear solenoid valve, no luck. At this point we knew it was the same problem as last time. The gears in the transmission were burred up and not allowing the teeth to slide together. Aparently these transmissions are not "field servicable" according to Haas and you have to send it in for a rebuild and the last time it was quoted i believe around $7000. The owner fixed it the last time, and i fixed this time. The transmissions are very simple. I spent two hours with a dremel tool deburring and knife edging the high gears teeth and had to replace one bearing. It was a common bearing that a place down the street carried. after cleaning and reassembly, it shifted like butter. Hope this helps somebody.
    Sep 2006
    51
    Good post fast89
    Jul 2003
    212
    How about the actual gears that are in there; Are they full custom design? Do you suppose they could be bought somewhere other than HAAS?
    2932
    You might want to check the relays on the I/O board. I believe they're K13 & K14. I don't remember if they're the replaceable type though. I've cleaned many a set of contacts to keep running while waiting for parts, but mostly on the tool carousel relays. Another thought to get you going; if you are stuck in low gear and you can run the program in low gear, I seem to remeber you can disable the gearbox with Param 57 "Disable G.B." This should ignore the mandatory gear-shift during power-up.
    Dec 2006
    54
    The gears were most likely custom Haas stuff but no gears needed to be replaced, just massaged. We had the gears grind twice before we took it apart, made an awful noise. That pretty much ensured they were burred and would not mesh together.
    Dec 2006
    54
    Well it looks like I spoke too soon or didn't knock on wood. The damn thing ground the high gear again today. It continued to work after that (knock on wood). I'd like to know why this machine will start the spindle when it is not engaged in any gear? There are double acting limit switches on the high and low position of the air shift solenoid, and yes i tested the shiznit out of them. They are four wire normally open/closed switches. Meaning that when the plunger is in, two wires have continuity, when the plunger is out, the other two wires have continuity. It would seem that there would be two switches telling the computer that it is not in gear.....so why does the spindle start? grrrrrr.
    Apr 2007
    178
    definitely drill out the restrictors between the copper lines and the black manifold base check the solenoids if they are norgren the coils usually fail and you can replace them cheaply from a norgren distributor. if they are mac they may be clogged or need to be replaced replace the oil in the gearbox. check the wires going to the coils there is no strain relief and sometimes they pull out. ahh the limit switches usually do not fail but it is always worth a look in diagnostics to see if it is in gear and they actually work
    good luck
    Dec 2006
    54
    Thanks for the tips serviceman. What do you usually drill lthe restrictors out to? We drilled the high gear out to .020" and it definatly helped the shifts to be more forcefull. We had also changed the mac valve when we had it apart. We've been keeping it in high gear since it ground just to be on the safe side. We were thinking of lowering the shift point to 500rpm or so so it would stay in high gear 99% of the time. The only problem is, upon startup it shifts low to high and back to low as part of is warmup. Is there any way to dissable this shift. We almost always use high gear and don't really care if we can't go below 500rpm. Most of the parts this machine makes are easy cuts, no 1" hog mill taking a 1" cut on crs or anything like that.
    Craig
    Apr 2007
    178
    we have done .030 up to .050 you can disable the gearbox parameter but if you disable the gearbox parameter then you have to make sure that you manually shift the solenoid into high gear, or know that you are in high gear and then swtitch the parameter. once a solenoid is opened in one direction it usually stays there. there will be no power going either of the coils from then on and it will not look at the switches. this will leave the machine in high gear all the time, but if the machine happens to drop out of gear you can run into problems but i have never seen that happen, but we never leave the machine running like that for very long and usually i think that you have to keep the air on the machine if you disconnect the air you have to check the diagnostics in the morning to make sure the machine is still in high gear. if drilling out the restrictors does not help then you need to take the trans out of the machine and replace the o rings on the shifter assembly. being careful not to bind up the shaft when you tighten it down.
    Nov 2009
    27
    Hi guys,
    I realize this is an old post but it is relevant to the problem I'm having. On a 1994 VF4 the solenoids were sticking, I ran it 200 RPM and it fell out of gear and ground for about 2 seconds before it was stopped. I have since fixed the shifting problem. Now when I run the machine in high gear, it has a significant grinding/rubbing noise as the spindle comes to a stop and most of my work runs at 6000 RPM. Otherwise it seems to be fine. Do you have any advise or thoughts. I'm really struggling on whether to run it until it breaks, (at that point it will cost $3500), take it apart and try to figure out what is wrong so it doesn't tear itself up (at that point it might cost me just my time or it could cost $7000 if I can't fix it since I would have committed the sin of trying to service it).
    Thanks for your help!
