Hello,
I am planning to implement the hossmachine CNC Z-axis mount. I have studied the drawings on the hossmachine site carefully. This leads to the following question: I note that there are two thrust bearings, a larger one on top and a needle flat on the bottom of the mounting bracket, but the belt drive creates a radial load in addition to the thrust load from the cutter. What carries that radial load?
Thanks in advance,
Peter
