586,818 active members*
4,725 visitors online*
    Feb 2010
    X2 Z-axis bearings...
    Hello,
    I am planning to implement the hossmachine CNC Z-axis mount. I have studied the drawings on the hossmachine site carefully. This leads to the following question: I note that there are two thrust bearings, a larger one on top and a needle flat on the bottom of the mounting bracket, but the belt drive creates a radial load in addition to the thrust load from the cutter. What carries that radial load?
    Thanks in advance,
    Peter
    Nov 2012
    174
    Re: X2 Z-axis bearings...
    If I recall correctly, the radial load is largely carried by the ball bearing nut riding on the ball screw. The thrust bearings contrain the ball nut vertically as the ball nut is driven to move the screw up/down, so the stiffness of the ball screw is what counters the belt tension. --md
  1. NM-135 X-axis bearings
    By spletcher1 in forum Novakon
    Last Post: 01-11-2012, 04:19 AM
  2. greasing the z axis bearings
    By woodman08 in forum Camaster
    Last Post: 03-06-2009, 01:40 AM
  3. which axis should have the best bearings
    By nicanor76 in forum DIY CNC Router Table Machines
    Last Post: 06-11-2008, 10:49 AM
  4. X Axis using V Bearings?
    By ratman in forum Open Source CNC Machine Designs
    Last Post: 12-03-2007, 07:59 PM
  5. z axis rods and bearings...
    By project5k in forum DIY CNC Router Table Machines
    Last Post: 10-19-2006, 04:14 PM
