586,823 active members*
3,340 visitors online*
    How the Rotary axis works
    A rotary attachment is a great help when you need to engrave cylindrical items like glass, mugs, cups etc. And it is also very simple to install the rotary attachment to your thunder laser cutter.
    Just place the rotary attachment on the work table and install the cylindrical item to the rotary attachment and move the laser head to the suitable place and adjust the focus distance.
    Then connect to the socket in the right side of the table and then press the switch to change the axis from Y to rotary axis. Now you can control the rotary attachment through the control panel. And you can press the button again to switch the control from rotary axis to Y axis freely.
    When the job is done, please take out the item carefully.https://youtu.be/mTiJjJ9CBwE
    www.thunderlaser.com
    Jun 2009
    77
    Re: How the Rotary axis works
    I like how it uses the rubber insert to hold the cup and do you have different size rubber to different size cups?
  1. Replies: 1
    Last Post: 11-17-2015, 07:37 PM
  2. Cheap rotary axis to play with dfx and pics works too.
    By minicncuser in forum DIY CNC Router Table Machines
    Last Post: 05-27-2015, 12:48 AM
  3. Problem with VSD-E in DualDC drive mode, axis 1 works but not axis 2.. any ideas?
    By bmquist in forum CNC Machine Related Electronics
    Last Post: 08-31-2014, 04:08 PM
  4. How Rotary Broaching Works
    By SwissType1 in forum Videos
    Last Post: 03-27-2012, 08:01 PM
  5. Replies: 1
    Last Post: 01-14-2012, 06:22 PM
