586,521 active members*
3,598 visitors online*
Page 1 of 22 12311
Results 1 to 20 of 438
    My First CNC, own design, buidling in progress
    Hi all,
    another member of a dutch scalemodeling Forum gave me this link, and now i got here, i might as well share my designs with you.
    last summer i got a PC and 3 stepper motors, to fit to a 3-axis milling machine, but i have one problem.. i'm a professional tool maker, and i want the quality that i have at work ( Bridgeport VMC800 ) so i designed a 3 ( 4th axis will be mounted on the table ) machine.
    Workspace will be 280 x 140 x 165 millimeters ( yup i'm from holland.. i dont work with inches.. too many numbers behind the comma )
    Maybe showing my design will rule out any design flaws i overlooked.. though building is already in progress..
    i also managed to get hold of a steel cabinet 100 Cm's high, and 70 x 50 Cm's top surface.. the milling machine wil be bolted on top, and i'm planning om making a casing/shield with plexiglass windows and a TFT screen in the door(s)
    Spec's sofar:
    Motor 600W router, 7000-30000 RPM's 6 mm collet ( smaller collets wil be made in the near future)
    stepper motors from Vexta, 2.5 A, 2.2 Ohms Nema 23
    Rexroth Ballrail guides and Ball spindles.
    Machine frame is made out of construction steel 15mm thick in most places except the X-axis guide bed which is 30x40 mm's 596 mm's long.
    Fourth axis will be built in a Unit which can be bolted on the table ( design hasn't been made yet, i'm still searching for small 4 jaw independent Chucks.
    Progress sofar: machineframe is finished, al parts are ground flat only the Z-axis milling head is still to be made, if that's finished, the rails wil be bolted on.
    2139
    What is it you will cut with it?
    What drivers will you use?
    Eric
    I wish it wouldn't crash.
    I bought drivers from www.stappenmotor.nl located in Holland.. 49.50 Euro's per axis, which basically means 200,- for 4 axes.
    the machine will be tough enough to machine steel, Bronze, PU, Resin, Foam, Brass, silver, and maybe even hardened steel.
    i'm building it to machine things like this:
    scale is 1:24, but i want to make more parts for scale modeling purposes.
    the PC is already "hooked-up" with the drivers, and some motors for testing.
    Currently the motors operate on 12V, but the drivers are able to use a current up to 30 Volts, so i'm also searching for a 30 V DC Powersupply.
    Bit of luck today.. i now actually have the steel cabinet, so i can start to take measurements to build the casing.
    2139
    Cool.
    The spindle rpm might be a little high for machining steel...but you know that since you are a tool maker.
    Let's see picturs of the build!
    Eric
    with a spindle speed of 7000 Rpm you'll get a 130m/min cuttingspeed with a 6 mm end mill, with this speed i'd be able to even machine Tool steel, and hardened steel with a solid carbide tool.
    30000 Rpm will provide a cuttingspeed of about 50 m/min to a 0.5mm end mill, will do.. a 2 mm end mill will run 188 m/min wich is perfect for machining steel. ( data based on Solid carbide tools) .
    Ok.. enough Tech-talk for now... Here are some pictures..
    Machine frame sofar, the mill head is still to be made, the guides must also be bolted on
    Yahooo !! Sparks!!.. flatgrinding the Z-motorsupport and the Z-spindlebearing support
    suport plates mounted in place, note: the Bearing support, in the bottom of the collumn is machined to size by now..
    Z-motor also mounted, to see if all would fit.. yup it fits like a glove..\
    Enjoy the pictures!
    May 2005
    674
    Lookin' good!
    Nov 2004
    131
    Wow, looks great.
    Great pictures too.
    ____________________________________
    Jeroen
    224
    Congratulations! Finally a precision small DIY mill with full support of the X axis.
    Hope it works as good as it looks like it will.
    It would be interesting to me to know what one would charge to build a machine like that.
    (i.e. make a living at it - pricewise)
    Good luck,
    Pres
    Quote Originally Posted by Pres View Post
    Good luck,
    Pres
    wat it will cost?.. if i'd have to make a living from building these, i'd be bankrupt in a few weeks... considering i constructed the entire machine, and i'm also building it, and it has taken me a full week to design the thing, and a lot of hours grinding, milling, drilling and so on..precision comes at a price..
    the Full X-axis support is needed to get the accuracy i want.. the 596 mm long supoprt beams are ground flat within 0.01 ( and that's before the X-axis Guides have been mounted )
    Yesterday i did another very important Job for this machine, i made 36 of these:
    T-Nuts 12X12X9 mm with M5 Thread to clamp future workpieces
    Jun 2006
    47
    ow my god! now that's nice! looks even better then a X3!
    goed bezig gast! Blijven posten zou ik zeggen
    Basically, all i did was take a good look at what i have at work, a Bridgeport VMC 800, and a VMC 610XP, the 800 has the long travel the 610 is equipped with ball rail guides..mix these two together, and what you get is what i designed.. ( japanese engineering, see what's around, and mixing the best features )
    X3?.. if the X3 is the "Sieg X3 mill" then i'd say.. "That's not a CNC mill, that's a conventional machine with a retrofit, still a drill press with cross slides, and the x-axisguide is just too short.. " But it's an affordable machine, which mine isn't by definition.. if i'd have to build them commercially, boy would it cost'ya
    Since i'm a toolmaker by profession, construction steel is available at low cost, so are the machines.
    The guides will be ordered shortly, we're building other machines for out R&D dept. at the moment, and those machines also have a couple of ballscrews , so mine will be ordered at the same time to get a discount..
    This is the table, i milled some pockets in the tableframe, to reduce weight, since this part wil run the highest feeds ( 2500mm/min )
    i'm considering to sell plans of this machine, though i'm not sure the design is "buildable" for others, since a lot of grinding is needed to straighten parts after milling..
    Arie,
    I'm impressed so far, it's nice to see that others have an eye for detail!
    I like your initial design, as its all steel!
    Eric
    Jan 2006
    357
    That is a fantastic looking machine!!, I will be watching this thead
    Today, i did some more "fiddling" with my Mini VMC:
    A detailshot of the Y-axisguide recesses, ground level with the topsurface, the runnerblocks will sit here.( it's upside down on the picture), when all is mounted it's level within 0.01 mm
    Also, on the rear beam, the Y-axis nut clamp.
    also, some milling done today, the ribs for the mill-head, always a challenge to mill things like this.. but the angle precision of the 90 degree angle is well within tolerances less than 0.002 degrees off.
    also some sawing going on in the workshop, the rectangular plates are still to be machined, but this will happen in a certain "procedure" which i have followed with all the other parts.. First cleaning the steel, Deburring, grinding!.. then , and only then, after grinding it's machined to size, and contours are milled, and holes drilled and tapped..
    the picture gives an idea what it is going to look like, there will be a hole in the bottom plate to fit the motor.
    and this is what it should look like if put together ( sorry no guides yet.. boss is on a holiday )
    Aug 2006
    74
    Wow! Very nice
    Good work
    how much for plan?
    How much?.. i don't know yet.. i also think i have to "symplify the design a bit, since i designed it to build it for me only, and being a toolmaker i have a fully equipped workshop at my disposal...
    how many people would have a workshop with CNC lathe's, CNC milling machines, a Wire-erosion machine (needed for my design of the Milling motor attachement ), and a table grinder with over 600 mm's of travel?
    especially the tablegrinder has proved Priceless with the fabrication of the X-axis guide beams, since milling out the recesses for the y-axis runnerblocks caused them to warp, and i grind everything back to shape.
    so i'd better think up something that's easier to build ( less recesses, less warp, though a slightly less compact design.. )
    Dec 2006
    68
    It's too pretty, I just want to get my scribe out and put a little scratch on it somewhere
    Aug 2006
    74
    I am a machinist and programer, I also have all the machine above at my disposal, but im not a very good designer,it would be a very nice project.
    Aug 2006
    1602
    Wow - that is beautiful!
    Ok, that'll just make it easier..
    i'll have to "redo" my drawings anyway, because i didn't specify any tolerances, or reference planes, which isn't a problem for me, since i designed the lot, but if i'm going to publish my designs, i want em to be Fool Proof..
    Furthermore: the design is based upon Bosch-Rexroth Components, but there is also THK and SKF Ballrail systems.
    I used Bosch-Rexroth, because they have a rail with blind holes , so no dirt can build up in the bolt-holes ( THK has the same distance between bolt holes so those can also be used, but a bellows must be fitted )
    Give me some time, i will also be designing some clamping devices, i'm not sure what those are called in English, but i mean those "Thingies" rectangular shape, with a slotted hole, and a threaded hole, to bolt down parts on the machinetable ( what are those called? )
Page 1 of 22 12311
  1. more progress..
    By adam_m in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 03:56 AM
  2. Design In Progress
    By JoeDawg in forum Uncategorised MetalWorking Machines
    Last Post: 10-07-2008, 07:48 PM
  3. My First Router Design & Progress
    By watsonstudios in forum CNC Wood Router Project Log
    Last Post: 07-22-2007, 09:19 AM
  4. Looking into buidling an Auto-start RPC
    By Wendell in forum Phase Converters
    Last Post: 10-12-2006, 03:03 AM
  5. Alibre design in progress
    By xyzcnc in forum Uncategorised CAD Discussion
    Last Post: 06-07-2005, 06:49 AM
