Don't you Dare!.. :withstupi I allready "messed up, note the small recess in the top of the vertical column (forgot Radius comp... )
Just "Dreamt up" i'm gonna fit some small nozzles around the milling motor, and use compressed air as a coolant, and also to blow away Chips, since Chip buildup in pockets and holes can ruin surfacefinish.. how's that?..
Since i also want to make a casing around this machine, i might even install a vacuum cleaner, to suck out all chips small enough to fly around ( i.e. Chips from finishing, more like dust than chips )
