Originally Posted by
handlewanker
Hi.......that lever applies a large part of the pump pressure by way of the leverage exerted to the pump plunger.
If you are applying 50Kg to the end of the lever this would probably be a ratio of 20:1 on the pump plunger......that means you need to apply a huge down force directly to the pump plunger.....not very easy to achieve.
In my opinion it would be simpler to make a connecting rod type link to push the handle up and down......I don't know how you could connect the motor to just the pump plunger, but no doubt with a clever bit of designing it can be done, but the force on the plunger would be very large without the handle to apply most of it.
I think maybe a direct connecting rod to the pump plunger attached to a flywheel with a crank throw of about 10mm "could" work with pulleys and vee belts to get the speed reduction........that might work out in the region of 1:100 reduction or more or you could use a bigger motor to pump at the same rate........but I think it will be more complicated to achieve, whereas the handle connection is simple.( uses a smaller motor) as it's already made to work in that way.
Ian.
