586,734 active members*
2,399 visitors online*
IndustryArena Forum > MetalWorking Machines > Shopmaster/Shoptask > Mill Turn caster wheel replacement
    Jan 2016
    11
    I purchased a demo/tester Mill Turn. As I received it, the caster wheel tires were falling apart. I replace the tires from WWW,sescasters,com. I believe the part number is WPHXKK3.112XXXR8S (A harder tire, phenolic wheel w/ bearing) (x4), reasonable price. I used the original caster and just replaced the tire. I had to spread the fork, of the caster, a tad, to make it fit, but no big deal. It rolls around great.
    Apparently, the original wheels are 250 lb. load test, as the Mil Turn is more than 1000 lbs. I would guess that the screw jacks were not used when demoing or testing and the original wheels should work fine if screw jacks are used after placement.
    Part #s, per packing slip are WMP03-221 (wheel), BR:1.2-1.38 (bearing), and SP:1.2-1.687 (spanner), but a one line item (x4) order.
    Jun 2006
    3063
    Re: Mill Turn caster wheel replacement
    FWIW, most caster manufacturers seem to recommend that casters be each sized for at least 1/2 the weight of the machine.
    Jan 2008
    458
    Quote Originally Posted by walters474 View Post
    You should have called JT- My machine had one bad caster, and he sent me a full set of 4 upgraded ones with a higher load rating, bigger bearings etc. for free.
  1. Mill Turn / Turn Mill / Multi Task C Y B Programming
    By aldepoalo in forum BobCad-Cam
    Last Post: 04-22-2015, 09:24 PM
  2. unboxed Harbor Freight X2 mill X axis wheel won't turn
    By dimitriosart in forum Benchtop Machines
    Last Post: 04-19-2013, 10:22 AM
  3. Replies: 1
    Last Post: 08-29-2012, 11:05 PM
  4. Calcomp 1023 roller wheel replacement?
    By futurestack in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 10-22-2011, 08:21 PM
  5. Encoder Wheel Replacement?????????
    By bill south in forum CNC Machine Related Electronics
    Last Post: 05-12-2006, 12:15 AM
