I have a design I can't find a solution for. Imagine a pievce of 8020 extreude aluminum tube, the 2020 to be exact which is a 2" x 2" OD square tube. Inside there is a Delrin nut that runs through the center on a 1/2 acme screw. This tube currently mounts vertically on a stand, permanently mounted to some legs on the ground. This tube supports 3 other arms with steppers moving stuff around to do some work. I want to take the vertidcal tube, remount it on some type of apperatus so that it can spin around 180 degrees, controlled precisely and smoothly by another stepper. I have no idea on how to mount this other than some crude flange that is metal to metal. Has anyone ever seen something that I could borrow from that is designed to rotate a vertical tube driven by a stepper for the full 180?
