586,655 active members*
3,087 visitors online*
Thread: RT Board ?
Results 1 to 11 of 11
    Jun 2015
    56
    RT Board ?
    Hello all,
    I have a RT fault on my Arrow 1000 A2100 control. RT board # 3-424-2168A02
    I have checked through most all the previous post on RT issues and went through to the best of my knowledge known causes, and also a call to Meckert to get his opinion.Just posting in hopes someone can help me quickly as I am mid job -big customer as always. I checked the batteries on both WS and RT board, both are good. Reseated both boards ( I say both because last week I had WS fault and reseating helped that issue - now this) . The lights on the motherboard light up on startup and then the left red light goes out , right (RT) stays on, as does the green.
    complete info of my problem as I start the mill follows :
    NC engine base failed (at 1st larger window)
    Runs small diag window - slows down on w/s bridge board but passes it , then fails rt board
    Runs through all 12 vickers application processes - no issue
    opens diagnostic manager and shows:
    Bridge RT- unknown
    Conv. servo - unknown
    i/o - unknown
    pendant - unknown
    w/s,key/touchscreen,and w/s processor - pass
    Question I have is - I am fairly sure its the RT board, Does anyone fix these besides siemens ?
    Thanks for the help.
    Oct 2011
    205
    Re: RT Board ?
    My guess is your power supply is faulty. I would start by swapping it out with a new one.
    Jun 2015
    56
    Re: RT Board ?
    OK, Thanks for the reply Coop. Do you know the specs on it ? I know its old style plug type but what wattage ? I like thermaltake in my pc's but doubt they make one.
    thanks
    Dec 2006
    584
    Re: RT Board ?
    It is an AT power supply not an ATX. I would go 300watts and do not use a cheep power supply. We use a STAR unit with a 2 year warranty.
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Dec 2006
    584
    Re: RT Board ?
    It is an AT power supply not an ATX. I would go 300watts and do not use a cheep power supply. We use a STARTECH StarTech.com unit with a 2 year warranty.
    Jun 2015
    56
    Re: RT Board ?
    thank you sir. So cloned HD today and will probably need the RT to get reflashed no matter what happens at this point, I think, because if it isnt faulty , it sure lost some function at some point. Maybe power surge or something...
    Mar 2007
    2083
    Re: RT Board ?
    adaptor cables are available to connect a standard ATX power supply to an AT mother board :-
    | RS Pro ATX Connector, Male 20-Pin ATX to 2 x Male 6-Pin AT 20-Pin ATX Male to Male 0.14m 2 x 6-Pin AT Multicoloured |
    one thing to watch out for is the later versions of ATX power supplies don't have the -5V output ( no white wire)
    only a problem if the mother board needs the -5V
    some DELL power supplies are wired in a non standard way - not a very bright idea to use a standard ATX connector
    Dell proprietary (non-standard) ATX design | Dell proprietary (non-standard) ATX design | InformIT
    its caused a number of DELL Pentium II and Pentium III computers to be destroyed when the power supplies have been replaced by a standard ATX supply !!!
    ( also HP have used non standard parts )
    John
    PS
    another ATX to AT power supply adaptor
    this one provides the -5V missing from the latest version of ATX supplies
    ATX 20 PIN to AT P8/P9 CONVERTER WITH -5V & ON/OFF SWITCH & DUMMY LOAD USA MADE | eBay
    Jun 2015
    56
    Re: RT Board ?
    Thanks for the info. I looked on the Startech site and can only find a 230 watt AT power supply. Will 230 watt do the trick or no good?
    Jun 2015
    56
    Re: RT Board ?
    OK, quick update. Finally back running again. What seems to have happened was a faulty floppy drive played hell with the Real time board and corrupted the board bios. So, send the board to get flashed/ reconfigured and now I am working fine so far. Got a new power supply for it as well, have not installed yet , old one seems fine. Thanks to everyone who helped.
    Jun 2004
    511
    Re: RT Board ?
    Who flashed the RT board?
    Jun 2015
    56
    Re: RT Board ?
    Maver1ck did the flash
  1. G0704 stock spindle control board to mach 3 via C32 board.
    By ballistic42 in forum Benchtop Machines
    Last Post: 09-22-2016, 02:47 AM
  2. Replies: 0
    Last Post: 11-26-2015, 10:34 PM
  3. Replacing BMU board in AMADA PEGA 357 (Instaling TULIP Fanram Board)
    By Spanish in forum Maintenance DIY Discussion
    Last Post: 11-21-2015, 02:58 PM
  4. Replies: 0
    Last Post: 11-30-2014, 05:16 AM
  5. Replies: 1
    Last Post: 06-01-2010, 05:31 AM
