586,975 active members*
2,967 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > need help with converting corel to g code
    Jan 2007
    I am new at this and trying to make stencils with fonts and designs from Corel Graphics Suite X3. My machine has Mach3 loaded with Artsoft. I would like to know how, after I create an image or name in the Corel program, do I save it so it will convert over to g code when I import it
    into Mach 3 for my router to carve the stencil. I have been trying to add
    a .dxf tag and that doesn't seem to translate - the program seems to
    want a .tap extension to work. I don't know the basic clicks to get to
    the point from my text or picture in Corel to get the router spinning. Can someone please help me. Thanks for any advice. Peggy Cary
    You need to export it from Corel as a .dxf or hpgl file. Then, depending on what version of Mach3 you have, you either use the .dxf importer or LazyCAM, one or the other should be under the file menu in Mach3. You then convert the file into g-code, which you save as a .tap file.
    Here's a Corel macro that may give you better results if you have problems http://www.candcnc.com/DXFToolDetails.htm
    Jan 2007
    thanks / more help needed
    Thanks - it worked and I am grateful. Perhaps you could
    help me with the next issue - the conversion worked and
    the g code shows up on the Mach 3 screen but for some reason
    my router will now only hum a bit. It is as if I need to reset
    something. It still works okay with some downloaded
    programs (ie - Write German Bravo) that were loaded
    with Artsoft - however, those fonts are very crude so
    I really need to use the Corel. Is there something I need
    to do to reset Mach3 so that the router will work after
    converting Corel to g code? Thanks in advance. Peggy.
    Do you have a feedrate in your g-code? Sounds like it's set too fast.
