H3ndrix,
RE: the internal grooves, etc in your spindle. If you gave me that job, I'd be scratching my head to do it in one piece like that, because working in a long slender bore to produce those shapes is a nightmare, as Ballendo implied
Perhaps there is no reason why you could not make that section of your ball retention, spring seat as a drop in cartridge. This would make construction much simpler, and you could also harden the hell out of the ball seats so that they don't wear out in short order.
Re: singular angular contact: not recommended, although I am not sure where you intended to make this change. What useful rpm range do you expect to run in? Have you contacted any bearing suppliers for a catalogue? Even an outdated catalogue will give you some numbers to mull over. I would recommend "The FAG Standard Program" from FAG bearings. There's lots of info about clearances, limiting speeds, etc that you should puzzle over.
