586,545 active members*
3,161 visitors online*
IndustryArena Forum > CAM Software > Vectric > Cut2D / Cut3D > Pocket around a profile
    Jul 2003
    92
    Hi.
    I'm new to Cut2D and just learning.
    My test is a .5" thick workpiece. I'd like to cut (profile) a hole all the way through, and pocket (to .125" depth) a recess around the hole.
    When I do this, it appears the pocket doesn't take into account the hole, so there is a whole lotta extra cutting of air.
    Think of this example as recessing a speaker driver in a baffle, so the hole is cut, and a recess added for the flange of the driver.
    I'm including two pics of what I'm see, I would have through the software would have "noticed" the through-hole and stopped pocketing.
    What am I doing wrong?
    BTW, it doesn't matter which order I perform the operations, pocket first profile 2nd or vice versa, I get the same result.
    Jul 2003
    92
    Re: Pocket around a profile
    I figured it out. I had to ad another circle inside and allow for at least enough room for the bit, select both shapes and then do the pocket.
    Pretty neat software for a guy coming from LazyCam.
  1. How to get Heeks to pocket or profile a circle?
    By Galane in forum OpenSource Software
    Last Post: 04-07-2015, 11:57 AM
  2. Advance Pocket or Offset Pocket
    By aldepoalo in forum BobCad-Cam
    Last Post: 01-31-2013, 07:46 AM
  3. Replies: 1
    Last Post: 11-30-2011, 07:51 PM
  4. How to profile a pocket with an end mill?
    By jamie1 in forum Mastercam
    Last Post: 10-27-2010, 01:48 PM
  5. How to profile a pocket with an end mill in mastercam?
    By jamie1 in forum Uncategorised CAM Discussion
    Last Post: 10-24-2010, 01:26 AM
