586,645 active members*
2,731 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Thread milling single lip vs full depth cutter
Results 1 to 16 of 16
    Oct 2014
    97
    I am approaching thread milling for the first time...I need a whole lot of 1/2-13 holes threaded 1 inch deep in 12L14
    Wondering what the pros and cons of the single lip miller such as Tormach sells vs full depth cutter like Maritool sells.
    Also considering grinding down a "trial thread miller" from a carbon steel tap , a 3/8-16 or 7/16 and leaving just one thread like the pictures of the
    carbide single lip millers ,........ just to see the process work one time ....at somewhat reduced thread depth....... and verify the feeds/speeds before trying an expensive carbide cutter.
    Any thoughts?
    Dave Lawrence
    7063
    Re: Thread milling single lip vs full depth cutter
    Are you asking about a single-point, vs multi-point thread-mill? If so, the differences are: Multi-point is faster, a lot more expensive, and can cut only a single thread pitch. Single-point is slower, cheaper, and each tool can cut a wide range of pitches. In terms of thread quality, there is no major difference, when properly used.
    Ray L.
    May 2015
    111
    John Saunders at NYC CNC did a video on Thread Milling..
    https://www.youtube.com/watch?v=uHIG49ZZYVY
    Might be helpful.
    Chris
    Dec 2008
    740
    The price difference is not THAT huge. Yes the single profile thread mills are a little more flexible but there are limits. It's not like you can cover all your threading needs with just one tool. For common threads I use the full length type but I have a couple of single form thread mills to cover the less often used ranges. For me it's a trade-off between cost and convenience. For some it would be initial cost vs time saved. A full length thread mill is a lot faster so your statement:
    Quote Originally Posted by DLawrence View Post
    implies to me that would benefit from using a full length type, depending on how many a "whole lot" really equates to. Divide the cost of the thread mill (or the difference in cost if you prefer) by the number of threads. Then determine how much your time is worth!
    I would also check out the variable flute thread mills from lakeshorecarbide. I haven't tried this type myself but their variable flute end mills are great.
    Step
    Edit: almost forgot, the full length types create threads with the correct thread form and will automatically give you the correct thread diameter. Single form thread mills are ground almost to a point and if the cutting diameter is used for the calculations without compensation you are likely to obtain a tight or "interference fit"!
    Nov 2007
    2151
    Quote Originally Posted by TurboStep View Post
    I like that term!
    What is the term when you use the same single point tool for both id. and od threading? I found with a little experimenting and you can get some crazy close fit threads.
    Should have known when I seen link to recent nycnc video above, was checking my email and some of my single point cutters I ordered last week are on back order and will not arrive with my backup Hamier probe tips , oh well these were backups also.
    Mar 2009
    1863
    Ray L.
    AND with a multi point thread mill if you need to recut your thread, you're screwed because there's no way to pick up the thread to recut it. With a single element tool, it's easy.
    Aug 2013
    980
    Another thing to check is the depth of threading you need to do. Often single points can thread deeper.
    Quote Originally Posted by Steve Seebold View Post
    Oct 2004
    178
    1/2 13 in 12L? Why not just tap it? Would be faster
    Dec 2008
    740
    AND with a multi point thread mill if you need to recut your thread, you're screwed because there's no way to pick up the thread to recut it....
    are you really sure about that???
    Step
    Dec 2008
    740
    For anyone who's wondering, a multi-point thread mill will pick up the thread in exactly the same manner as a single point.
    A multi-form thread mill for about $105 isn't that much more expensive than a single point thread mill capable of cutting the same thread. Also, don't forget that a single point thread mill has only one row of teeth. A 1/2-13 multi-form thread mill with a cutting length of 1" will have 13 rows of teeth to do the same work, will therefore last a lot longer, so will actually work out significantly cheaper in a production environment, and that's not even considering the time savings.
    Step
    Jun 2008
    1082
    I'd recommend starting with a single-point mill. It'll make your threaded holes and give you some experience with thread milling. After a while I bet you'll want to go with multi-point mills for the time savings. At that point, you'll have a nice 60° back-chamfer tool for later.
    Feel lucky that you're doing such large holes. My first attempt with thread milling was some 6-32 holes and I used a multi-point thread mill. This was with a TAIG mill. The first hole seemed to go OK. The second snapped the tool almost instantly.
    Aug 2015
    368
    I use the singles from Tormach, they are great. Aluminum, titanium, delrin, same bit, lots of holes, it's super nice to be able to play with the major/minor Dias, pitch etc ... I couldn't be happier...I don't think anyways.
    Sent from my SM-G900V using Tapatalk
    Oct 2014
    97
    Standard Feedrate calculator on lakeshore carbide site says .0025 -.0035 (inches/tooth) feed in low alloy steel for 1/2-13
    I just got a single form FOUR flute 3/8 tool cutting dia
    I think some single form tools may have 6 teeth ...they would feed in faster wouldnt they ? a full depth cutter with 13 rows of 4 teeth
    't it (52 teeth times .0025 ?) wouldn't it need to feed in slower? Whats the principal behind this (inches/tooth) stuff ?
    How can I use the inches/tooth to determine feed in PP conversational ? or in handwritten Gcode ?
    Dave Lawrence
    Jan 2013
    97
    Diametral teeth, not vertical teeth. Treat it like a 4 flute end mill. 0.0025/tooth x 4 flutes = .010"/revolution.
    7063
    Unless PP allows you to correct for path radius, using a feed/speed calculator will give you the wrong feedrate. For a threadmill, the effective feedrate at the cutting teeth is much higher than the linear feedrate in the g-code F-word, due to the small path radius. Good F/S tools (like HSMAdvisor) will calculate the correct values, based on the tool and thread diameters, chipload, etc.
    Ray L.
    Jan 2004
    3154
    Dave Lawrence
    You don't need to handcode. Download a free thread coder from a threadmill manufacturer and cut&paste the code.
    A threadmill will cut a 1 inch deep thread in 2 passes (a few seconds) vs 26 - 39 passes for a single (min+/hole)
    www.integratedmechanical.ca
  1. Single point thread milling
    By dlenardu in forum Milltronics
    Last Post: 01-19-2014, 04:16 PM
  2. Single profile thread milling
    By JOE OMNI in forum Okuma
    Last Post: 11-28-2012, 08:17 PM
  3. .5" 316ss Single pass full width of cutter?
    By KVD in forum MetalWork Discussion
    Last Post: 08-10-2010, 11:29 PM
  4. single point thread milling
    By sensph in forum Rhinocam
    Last Post: 07-06-2009, 09:10 AM
  5. Thread milling with single or multiple inserts?
    By magneto259 in forum MetalWork Discussion
    Last Post: 04-12-2007, 04:39 PM
