586,753 active members*
7,501 visitors online*
IndustryArena Forum > CAM Software > Mastercam > got a new post, needs to be modified for g83/73
    Aug 2011
    121
    in Mastercam when I create a g73 chip break operation I only get the option to enter "first peck" and all others "subsequent peck", "peck clearance", "retract amount", "dwell", and "shift" are all inactive. The post outputs a V,Q,U, and D variable that all default to .1". I am going to get this post modified as I have a maintenance license with Mastercam, but I just want to be sure of the following: V= first peck depth, Q= subsequent peck depth, and D= retract amount? What is the U variable? also what is shift?
    As for g83 my post outputs a V,Q, and a D, which I believe to be correct as I should only need 3 variables to peck drill? or am I missing anything
    Sep 2009
    93
    Re: got a new post, needs to be modified for g83/73
    The variables will depend on the control manufacturer so I would read the manual supplied with the machine
    Sent from my SM-G900V using Tapatalk
  1. Modified cnc 3020
    By BOATDUDEGUY in forum DIY CNC Router Table Machines
    Last Post: 08-02-2013, 01:17 PM
  2. G76 Modified Threading
    By lathe_man in forum Hardinge Lathes
    Last Post: 04-29-2010, 12:25 PM
  3. Another modified Joe's 2006 CNC
    By DeWalt58 in forum Joes CNC Model 2006
    Last Post: 03-20-2008, 10:44 AM
  4. Modified JGRO
    By ZOB in forum Commercial CNC Wood Routers
    Last Post: 05-13-2007, 04:48 PM
  5. Modified JGRO
    By ShayArnett in forum Commercial CNC Wood Routers
    Last Post: 05-06-2006, 02:33 AM
