587,066 active members*
3,338 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Why use a pulse index card?
Results 1 to 9 of 9
    May 2008
    56
    I have a C3 pulse index card for my G0602 (working great), and am going to add a second spindle sensor so LinuxCNC sees both an index pulse and a phase pulse. I really have no idea why I'm using the C3, other than everyone else does it.
    What exactly does this card do, and why can't I just run the sensor right to my breakout board (mine is a C11)? Would running the sensor straight to the BOB input (instead of the C3) not work? Or is it just not ideal?
    I don't mind buying a second C3, just trying to understand its function.
    Thanks.
    Nov 2009
    4415
    Re: Why use a pulse index card?
    Why would it be any different than running the same type of switch for a limit? The only thing that would be a concern is the ability to read the signal fast enough. I run my limits direct, well with a resistor but that is it. Try it.
    A lazy man does it twice.
    May 2005
    1662
    Seeing as this went unanswered......
    I'm not an electronics guy by any stretch and will gladly stand corrected on what follows, I've learned lots from posters correcting
    my baloney
    The main thing the C-3 will do in your application is provide a comparator circuit (schmitt trigger?). The signal output and the
    sensor are parallel so some current is present at signal even if the sensor is closed The comparator provides true on/off.
    The C-3 also appears to have a capacitor across 5+/ground and some resistors to limit current. The basics of the C-3 can be
    seen in this link:
    DAK Engineering - CNC Threading
    The optical limit switch sitting on my desk has a 15 microsecond transition time, faster than 60 slot encoder at threading rpm. How well
    it would work without further clean-up I don't know. Why not experiment ? Sounds like good geeky fun if you have the time.
    Anyone who says "It only goes together one way" has no imagination.
    Jul 2008
    267
    Like cyclestart says, it cleans up the input signal into a nice digital signal.
    To add to the "geeky fun" If you have access to a two channel scope (with decent input impedance), put a channel each on the input and output and you will see the difference.
    May 2008
    56
    That's sorta what I figured. I'm only a little familiar with Schmitt Triggers so I'll read up on that just for fun. I don't have access to a scope but I was thinking the same thing. I may need to have one of my friends bring his over so I can play with it.
    Thanks!
    May 2005
    1662
    Linuxcnc has halscope
    Attachment 309086
    The top signal is a C3 picking up an index, the bottom signal is a cheap optical limit switch reading 60 slots/rev. Looks much the same to my untrained eye.
    Ignore the uneven phase-a spacing, the encoder disk used was pretty dodgy.
    This was only tested up to 600 rpm (again the dodgy disk), at higher speeds the C3 may show it's advantage.
    One thing about the C3 is the 'throat' is kind of shallow restricting how far the beam can be from the outer edge of the disk.
    If anyone finds this useful great. If not I killed a cold winter day and had some fun doing it.
    Jan 2005
    15362
    Quote Originally Posted by cyclestart View Post
    Attachment 309086
    Good job, it's always interesting to see what others do with there software, You did say the disc was not accurate, but is the disc that far out, the spacings are not very good, it would be interesting to see the C3 with the same disc, the form is not going to change that much, the spacing accuracy is what needs to be accurate
    Mactec54
    May 2005
    1662
    The disk looks like it was carved with a butter knife. It was cut on a cnc router but the mystery material gummed up the cutter.
    So yeah, pretty bad. When I find a better piece of sacrificial material the experiment will be run again with both units running on the same ring of slots, At higher rpm too.
    May 2008
    56
    Attachment 309086
    Very cool. Thanks for posting
  1. Leadshine MX3660 and index pulse card
    By Blakea1790 in forum Benchtop Machines
    Last Post: 01-07-2014, 07:13 PM
  2. C3 Index Pulse Card and G540
    By blades in forum Gecko Drives
    Last Post: 04-15-2011, 06:19 PM
  3. G540 and C3 index pulse card
    By cmanning in forum Gecko Drives
    Last Post: 02-12-2010, 02:09 PM
  4. G540 and C3 index pulse card
    By cmanning in forum G-REX
    Last Post: 06-30-2009, 08:46 PM
  5. CNC4PC C3 Index Pulse Card - Help
    By TravisR100 in forum CNC Machine Related Electronics
    Last Post: 06-30-2009, 01:50 AM
