586,761 active members*
7,378 visitors online*
    Sep 2013
    bridgeport ez track dx 1996 boot problems
    Hi there, what i read in this forum,this machine has a hard drive and doesn't need a flopy disc,someone please help me with this screen that appear in the monitor,
    before i change the battery of the board and i was trying to set it up but i can not move from there.
    Jun 2007
    129
    Re: bridgeport ez track dx 1996 boot problems
    The bios does not see any hard drive. Check to see if the drive cable in correctly in the connector on the motherboard and also check to make sure a power connector is attached to the drive. If everything is connected correctly, measure the voltage from the power connector and also make sure no pins are bent or not making connection on the mother board. Cables are usually keyed to make sure they cannot be installed incorrectly.
    Sep 2013
    Quote Originally Posted by reabdet21 View Post
    Thanks a lot, I will check everything that you recomend.
  1. my Biesse Rover 13 ; 1996 Startup problems
    By peteviko in forum CNC Machining Centers
    Last Post: 09-16-2020, 03:41 PM
  2. New to me 1996 Torq Cut 22 Bridgeport
    By Bill Gillen in forum Bridgeport / Hardinge Mills
    Last Post: 10-05-2012, 03:34 AM
  3. 1996 Miyano BND34S-2 Problems
    By Frazier&Son in forum DNC Problems and Solutions
    Last Post: 12-30-2008, 10:46 PM
  4. Bridgeport Vmc 1000 1996
    By skydivebase in forum Bridgeport / Hardinge Mills
    Last Post: 05-08-2007, 11:18 AM
  5. Boot disk for EZ-Track DX, batch file?
    By mmm2003 in forum Bridgeport / Hardinge Mills
    Last Post: 01-31-2007, 06:47 PM
