586,504 active members*
3,315 visitors online*
IndustryArena Forum > Additive Manufacturing / 3D Printers and 3D Scanners > Electronics > Controller for 230v 1.75 hp treadmill motor?
Results 1 to 14 of 14
    Mar 2014
    1131
    I just purchased a treadmill motor to upgrade my lathe. The motor is 230v 1.75hp DC continuous duty. I don't have a controller for it yet. At this point I'd like to ask you guys if you know a good controller that I can use with.
    Suat
    24223
    Re: Controller for 230v 1.75 hp treadmill motor?
    There are KB DC motor controllers both SCR bridge or PWM, PWM being the superior one.
    Al.
    Mar 2014
    1131
    Thanks Al. I've been reading KB item manuals, I think this one is what I need (can't be totally sure though):
    http://www.kbelectronics.com/data_sheets/kbws.pdf
    One other question, how do I do the reversing if I use this controller?
    24223
    You will need a reversing contactor on the motor leads, you will also need to close the Inhibit terminals so that the drive is reset and comes up in acceleration, do not reverse without this when the motor is running at the time.
    Al.
    Mar 2014
    1131
    Ah I see. I thought the controller do the reversing.
    Thanks for your help.
    Mar 2014
    1131
    Actually I'm not reading very good things about treadmill motors used in cnc machines as they don't last long etc. I'd like to use an AC 3 phase motor but the available room for motor in my lathe seem to be small to put a 700w and more.
    24223
    The Johnson line of T.M. motors are pretty good quality.
    https://www.johnsonfit.com/blog/trea..._of_horsepower
    Al.
    Mar 2014
    1131
    Thanks Al.
    Mar 2014
    1131
    Hi again. I bought a KB PWM controller but I need to ask about the HP resistor plug-in that the controller needs to run. Is that HP resistor unique and something that KB manufactured or is it just a resistor (electrical component) with the correct OHM value?
    I'm asking because the KB branded resistor I need is 0.1 OHM #9838 P/N item and is cheap however the shipping cost from US to TR is way too high (cheapest on ebay is about $20). So if it's just a resistor then better I get it from locals.
    24223
    You can use any make of resistor of the correct value and wattage.
    Just that it comes with pins to plug it in.
    Al.
    Mar 2014
    1131
    Awesome. Thanks Al.
    Mar 2014
    1131
    Al.
    Al,
    What type of a switch do I need? I think the switch has to have extra foots for the inhibit connection.
    24223
    Might be easier to do it with a SPST switch and use a relay, the switch that KB uses and comes with the enclosure models have a terminal for the braking resistor and the I1 & I2 terminals, it also has a special centre position stop that prevents you from going from FWD to REV in one motion.
    If you need the switch if you have a KB or Baldor motor rep near you they should stock it.
    Al.
    Mar 2014
    1131
    Is it something Baldor/KB branded/manufactured? I couldn't find info about SPST on-off-on switches. The one I have is: IC158 6 AYAKLI ON-OFF-ON B
  1. Manual control of MC-2100 treadmill motor controller?
    By murph64 in forum CNC Machine Related Electronics
    Last Post: 02-10-2024, 10:00 PM
  2. DC Motor Controller & Driver 2hp ( 2kW ) Treadmill Motor
    By hesham morsy in forum Open Source Controller Boards
    Last Post: 01-27-2014, 12:50 PM
  3. 7x treadmill motor and speed controller conversion
    By maxboostbusa in forum Mini Lathe
    Last Post: 01-15-2014, 11:28 PM
  4. Controller help: 130VDC treadmill motor on 220VAC supply
    By ChrisAttebery in forum CNC Machine Related Electronics
    Last Post: 03-06-2013, 09:04 PM
  5. Need Help! 5HP motor 460V to 230V?!
    By diyengineer in forum CNC Machine Related Electronics
    Last Post: 10-25-2010, 12:08 PM
