586,551 active members*
3,562 visitors online*
Thread: Edgecam post
    May 2007
    Question Edgecam post
    Looking for a post for a Mazak Hyperquadrex 150MSY. Can anyone help out?
    Oct 2009
    47
    Re: Edgecam post
    Hi Doyle,
    Edgecam installations include the Code Wizard, which is a great software tool for users that want to handle post processor modifications. If this is what you're question is about, you should start a "new machine", lathe type. This will present a dialog which is configure to match the physical machine capabilities. At the bottom of the box is the preferred units (although Edgecam posts are dual unit capable), and the template. The Adaptive Integrex is a good choice for any Mazak turning center with a Matrix / Matrix II / SmoothX control. This will provide "library post processor" code, and further modification is possible using Code Wizard to dial the post processor to the specific capabilities of the CNC machine, as well as accommodate user preferences.
    If you're looking for someone else to provide a post processor for you, it is usually best to contact the company that provides software support to you. Many Edgecam VARs have technical expertise to tailor "library post processors" to your company's specific CNC machine.
    Hopefully that points you in the right direction.
    May 2007
    Re: Edgecam post
    What I'm looking for is someone to share posts with.
    Feb 2011
    10
  1. Edgecam Dmu 50 post
    By erhanery in forum EdgeCam
    Last Post: 10-22-2013, 11:31 PM
  2. EDGECAM Post for YOU JI
    By pr.vibin in forum Post Processor Files
    Last Post: 06-07-2011, 11:16 AM
  3. EDGECAM Post for YOU JI VTL
    Last Post: 06-07-2011, 11:13 AM
