586,917 active members*
2,540 visitors online*
Results 1 to 2 of 2
    Mar 2013
    26
    Belt reduction or planetary gearbox or other ?
    Hello, I'm new to this forum, but I would like to clear a bit my doubts and if somebody can enlighten me and suggest I would really appreciate it.
    We have bought an old oxyfuel / plasma gantry cnc cutting table. It is a fairly big one, it have rails of about 10000mm and large about 5000mm. All is made of steel and the gantry is about 500kg in weight i estimate.
    Just doing the retrofit, as the machine was without any cnc stuff on it. So no motors, no drivers no gearboxes. I have basically just steel structure and the 3 oxyfuel torch lifting devices which they seem in a good state and
    with motors.
    So now here goes my question. The rails are made of a square steel tube where there is a guide and a geared rail on it. I would like to understand which kind of gearbox or belt reduction should i use ?
    The servos I plan to buy are from DMM Tech , the 11A-DST , 1kW servo motors with respective drivers. It was suggested to me by the DMM team. They said that probably I should use an 2:1 belt reduction.
    So which belt reduction should I use, any suppliers anybody can suggest ?
    Or should I go with the planetary gearbox mounted on the motor directly and then put on the gearbox a spur gear to fit into the geared rail ?
    Or maybe some other kind of solution ?
    I will step by step do the drawing on the whole machine in solidworks and if somebody will need it i can post it here.
    Rgds
    Saxa
    Mar 2013
    26
  1. Planetary gearbox or belt reduction
    By ramsey321 in forum DIY CNC Router Table Machines
    Last Post: 05-20-2013, 01:02 AM
  2. RFQ: Aluminum Plate for Planetary Gearbox
    By nyjack in forum North America RFQ's
    Last Post: 06-28-2012, 12:31 AM
  3. PLANETARY GEARBOX
    By BOBINETTE in forum Stepper Motors / Drives
    Last Post: 07-12-2009, 10:16 PM
  4. High Precision Planetary Gearbox
    By automationtechinc in forum Automation Technology Products
    Last Post: 09-30-2008, 05:09 PM
  5. PLANETARY REDUCTION GEARS
    By SNERLAND in forum Servo Motors / Drives
    Last Post: 03-06-2008, 06:00 PM
