586,779 active members*
9,529 visitors online*
IndustryArena Forum > MetalWorking > Moldmaking > Wiring help needed for BOY 15 molding machine
    Feb 2005
    10
    Need schematic or some sort of wiring diagram for BOY 15 built in 1974. It's an old machine but in very good condition. I plan on running this machine off of a 15 HP phase converter. I will hear a sound change on my phase converter when I turn the molding machine on, but nothing happens, not even the sound of a relay click. I attached my incoming wires one at a time replacing the three and ground in the same locations the old ones where in, but I suspect they are not in the correct locations. A schematic would make this a whole lot less painful. Thank you. Fred
    Aug 2005
    158
    Re: Wiring help needed for BOY 15 molding machine
    I can't help you with a wiring diagram but did you try flipping 2 of your 3 phase wires?
    www.decalpro.ca
    Jul 2006
    68
    Quote Originally Posted by ffulmer View Post
    Did you get it running?
  1. Help needed for small mill to cut molds for an injection molding machine
    By gperkins in forum Uncategorised MetalWorking Machines
    Last Post: 08-15-2014, 08:12 AM
  2. Low cost injection molding machine
    By Edison4 in forum Videos
    Last Post: 06-01-2012, 03:38 PM
  3. DHC Supermax 165 & 110 ton molding machine
    By Russellcw in forum Moldmaking
    Last Post: 10-09-2008, 04:24 PM
  4. zrn for molding machine
    By scr in forum DNC Problems and Solutions
    Last Post: 09-02-2007, 05:37 PM
  5. Replies: 2
    Last Post: 06-23-2007, 01:57 AM
