well I tried to post a good explanation for you, but the computer locked up. I will try again.
I am not aware of an electric welding process for aluminum that involves flux, such as flux core wire welding or stick (arc) welding
Your options are:
1. Oxy fuel, fairly inexpensive, but only recommended for the seasoned welders out there. Not recommended for rookies!
2. Large-ish MIG (GMAW)with spoolgun attachment. Aluminum wire does not like to be pulled or pushed long distances, so it will flatten and "bird nest" very easily. A spoolgun has a spool of wire within inches of the fusion point, so there is no long feed distance
be prepared to spend 1000 + for the MIG , and another 500 for the spoolgun
3. TIG (GTAW) is by far the most expensive method, but also the nicest, IMHO. You can "weld ice cream to air" with a good AC/DC switchable TIG.
Be prepared to spend at least 1000 for a introductory AC/DC unit.
Sorry I know this is not the answer you are looking for. I have had dozens of different welders over the years, and there just is not a viable option,when it comes to welding aluminum, for anywhere near the 200 dollar range.
The best you can hope for is a miracle on Ebay for that amount.
"If the women don't find you handsome, they should at least find you handy"
-RedGreen show.
