586,392 active members*
2,901 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Macro alarm "009 ILLEGAL ADDRESS INPUT"
Results 1 to 8 of 8
    Nov 2005
    219
    First I want to thank everyone who helped me get this far but apparently I am missing something. I am trying to engrave on the O.D. of a piece of 2." round stock on my Lathe.
    Have a look at the macro prg. below and that part prg. and tell me if you guys see whats wrong.
    It gives me a "009 ILLEGAL ADDRESS INPUT" ALARM.
    I am trying to take the Y values in my prg and convert them to C-Axis moves in degress with the macro.
    Macro prg below....
    O9100(2.00 DIA MACRO CALL)
    G01C[#25*.0174]
    M99
    Part prg below.....
    O1569(OVAL)
    N2#501=2.00
    N3#502=[501+.1]
    N4G10L2P01X0.Z-23.4684
    N5G10L2P02X0.Z-3.0123
    N6G10L2P03X0.Z-20.4684
    N7G10L2P04X0.Z-12.1784
    N8G10L2P05X0.Z-5.3333
    N9G11
    N10/2M98P9998
    N12M118
    N13G28U0
    N14G28B0
    N16G99
    N17G54M54
    N18
    N19(CHAMFER)
    N20G50G99
    N21S3000
    N22T1010G54
    N23G0G96S1000M3
    N24Z0M8
    N25X2.1
    N26G1X-.07F.006
    N27G0W.05X1.7069
    N28G42G1Z0.F.006
    N29G3X1.7634Z-.0117R.04
    N30G1X1.9766Z-.1183
    N31G3X2.0Z-.1466R.04
    N32G1G40X2.1
    N33G28U0M9
    N34G97
    M05
    M01
    T1213
    G98
    G54
    G0X0.Z.1
    M69
    G04P0500
    G01Z4.0F500.
    M68
    G4P0500
    G0W.1
    G28U0.
    G98
    N39T0505(BALL END MILL)
    N40M43
    N41G56G0C0.
    N42G97S4000M13
    N43G0Z0.
    G0X2.1
    G01X2.F20.
    G66P9100Z.0002Y.0117 This is where it alarms out....
    N56Z.0007Y.0233
    N57Z.0017Y.0349
    N58Z.003Y.0466
    N59Z.0046Y.0582
    N60Z.0067Y.0698
    N61Z.0091Y.0814
    N62Z.0118Y.0929
    N63Z.015Y.1044
    N64Z.0185Y.1159
    N65Z.0223Y.1274
    N66Z.0266Y.1388
    N67Z.0312Y.1502
    N68Z.0361Y.1615
    N69Z.0414Y.1728
    N70Z.0471Y.184
    N71Z.0531Y.1952
    N72Z.0595Y.2063
    The prg goes on for another 1600 lines....
    thanks Jon Thee
    992
    Quote Originally Posted by theemudracer View Post
    I don't think you can use the letters that use as machine command address like G O Z Y X H few others.
    The best way to learn is trial error.
    Nov 2004
    56
    Have you tried it this way?
    #503=[#25*.0174]
    G01C#503
    M99
    Nov 2004
    56
    Missed read program to start so skip me first post..
    Question- Are wanting the Z and Y to feed at same time as C?
    If so The Z and Y move needs to be on same line as C.
    G01C[#25*.0174]Z.0002Y.0117
    Nov 2005
    219
    Quote Originally Posted by CBNDude View Post
    My lathe only has Z, X and C with a sub spindle B.
    I am wanting to take the Y axis moves in the prg and feed C axis in degress in its place.
    thanks Jon
    Sep 2005
    767
    The Y address may not be permitted on a lathe. For the purpose of calling a macro, you can use any other address that permits decimal points, like "A".
    Also, CBNDude is right. If you want the Z axis to move also, you've got to make it move in the macro. The G66 macro call will just pass the numbers to the macro, and it won't move the axes at all. Try this to call the macro:
    G66P9100Z.0002A.0117
    Then, inside macro 9100, move both the Z and the C axes with a single G01 command, like so:
    G01C[#1*.0174]Z#26
    There should be a chart in the front of your operator's manual that will tell you the legal addresses, and it will also tell you which addresses can use decimal point formatted numbers and which ones are simple integers. For example, an address X, Y, Z, U, V, U, or A, B, or C should accept decimals. The addresses M, T, S, etc. are integers. Your lathe may not permit the addresses Y, B, or V because this axis doesn't exist on your machine.
    Just a guess ...
    Nov 2005
    219
    ok that makes sense now.
    I will report back after christmas.
    thanks again
    Jon
    May 2006
    265
    I dont think it is possible to do this on a fanuc 18IT.. Mabe it is possible to scale one axis (c-axis) (mabe scale it in the text producing prg).and change the Y to C in a simple text editor..
