I have been presented with a unique opportunity to design a machine to be produced by a machine manufacturer (no affiliation whatsoever) and would like to share this opportunity with a group of people who may also be interested, who have design experience, and are interested in a collaborative design project resulting in an actual machine that would be available when finished at a reduced price for the design work out in. The plans would be the property of the manufacturer at the end of the project and they would manufacture and sell to the public. This seems like a good opportunity to finally have a machine with what we all here seem to want from what I have seen in
As I'm sure many of you have experienced, After a long time (5 years) of using a cnc G0704 and considering upgrading it further, converting other machines or a scratch built mill from steel or epoxy granite, I always wound up finding myself compromising the desires of a small converted mill or snapping back to reality the reality of an intensive multi year long build and not wanting to commit to such a project and switching gears and looking at VMC's which of course have all the features desired, but present their own list of obstacles not the least of which is a giant up front cost.
This led me to begin researching and reaching out to various machine manufacturers in China for an alternative of which I found a few but always with subpar travels for the expense, albeit having most of the other desired features.
After long discussions with several of these manufacturers, I found one who impressed me very much, had VERY reasonable pricing, and who was the most willing to be flexible in modifying their existing machines to suit my criteria. After much back and forth discussion and pictures and design considerations on my end.. The manufacturer suggested that changing an existing machine may not be the best course of action and offered to build a new machine based on my designs. I considered this for a few weeks and then thought that it may be worthwhile to expand the thinking on such a machine to a broader input group so maybe it benefits the forum members more.
So, here I am, requesting some other forum members who are looking for more then whats out there and less then a full blown vmc. The goal will be to design a new machine to be cnc ready and/or offered to varying degrees of completion for a DIY. This will be a machine a little more suited to production then what is currently available in the small mill category. The machine design will have a compact layout and minimal footprint and required access space. It will not be as big and cumbersome as a full VMC and will solve the issues they come with such as 3 phase requirement, giant space requirements.
The new design should have easy access to components for servicing, access from the front or sides of the machine for electronics and coolant system and chip management. Machine should be Manageable with a pallet jack and freight truck lift gate for easy delivery, fit through a 8' garage door fully assembled with head down and blocked and 7' garage door with minor components disassembly. Complete with all components for DIY assembly for motors, wire management etc.
Other Design criteria I have come up with after a lot of searching and research and personal experiences are as follows, and of course as a collaborative effort, completely open for discussion.
- BT30 Spindle ATC type w/ pneumatic drawbar and belt drive system and motor provisions (seems to be the best compromise between cost, rigidity, tooling costs)
- Travels X-30" Y-15" Z-20" with all axis quality hiwin linear rails
- Table size 12" X 46"
- Ballscrews P4 C5 double nut ground
- Automatic lubrication system
- Way covers
- Modular enclosure for toolroom or fully enclosed design with upgradable option
- Positioning accuracy .02mm (.0007"), repeatability .01mm (.0003")
- Automatic tool changer (12 tool carousel exists already, if an arm type is desired will need to be designed)
- Electrical design and layout for cabinet. Provisions for powering a 5hp vector duty motor with VFD drive with spindle indexing, Axis servos /Steppers and drives, axis home and limit switches, power drawbar, automatic lubrication system, 4th and 5th axis expandability, ATC, Probing and tool setting, glass scales (possibly?), Lighting, washdown, chip conveyor, anything else I may be forgetting or not considering.
I'm certain I have left out items but that is where many minds will prevail. With fusion360 available for the hobbyist at no charge it seems like a good platform to develop the machine design in and collaborate in. I personally have little experience with fusion and use solidworks which I am proficient in, but luckily most everything is compatible now days so those like me with solidworks background aren't left out.
So lets start this discussion. From my length of time of discussion and many many requests and persistence I have a been given direct access to the manufacturer tiring companies, CEO who can help guide the design process by critiquing the designs based on manufacturing difficulties that will drive costs up. His company has been manufacturing machines since the mid 1950's and he brings a wealth of first hand knowledge with regards to casting and machining the components of the machine design.
It really is one of those rare instances where we get to make something we actually want rather then be constrained to a companies ideas of what we should have. The one caveat is that we will need to have a group who will be interested in purchasing the machines when completed. They would like to see at least 10 machines but are flexible and easy to work with. Based on their other pricing I have been given, I think the costs will be lower then what one would expect, and we can get some rough estimates early on in the design phase and use them to guide the machine designs to stay within a certain budget and make items optional so as to keep the modular concept working to allow initial costs to remain low but have expandability down the road.
So who would be interested in such a project?
1- Chris (Lcvette)
2-
3-
4-
5-
6-
7-
8-
9-
10-
Chris
Sent from my XT1080 using Tapatalk
