586,594 active members*
2,784 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > can't bore jaws with chuck open
    May 2015
    35
    Okuma LNC 8 Cadet with OSP 5020L control, So I get set up to bore my jaws and turn the spindle on, it starts to spin and suddenly stops with a 119 chuck open alarm. I shut it down and hoped it would reset but no. Now it won't even try to start. No alarm now either. Spins fine with jaw closed in manual setting. Anyone run into this before? Any suggestions?
    Apr 2009
    1262
    Re: can't bore jaws with chuck open
    There are 2 prox switched on the back of your actuator that need to be adjusted so that only one of them is on at a time. One is for unclamp and one for clamp. In the event that your chuck over travels, the alarm occurs. You will probably need to unclamp and reclamp in order to start running the spindle again.
    BTW, you should still be clamping on something in order to bore your jaws correctly and you should stay in the middle of your stroke as shown on your master jaw #1 markings in order to maintain good gripping pressure. You may need to bore at a reduced pressure and then return to your normal pressure once bored.
    Another possibility is to use the M185 Chuck Rotation Interlock OFF if your machine has the option.
    Best regards,
    May 2015
    35
    Quote Originally Posted by OkumaWiz View Post
    Best regards,
    How do you clamp something to bore out the jaws? A big ring?
    Jun 2011
    124
    Quote Originally Posted by Jmooresshop View Post
    http://m.youtube.com/watch?v=dRMm9P9XdbY
    Or
    http://www.cnczone.com/forums/general-metalwork-discussion/43353-cnc-machinist.html
    May 2015
    35
    Thanks. This helped a lot. I'm very grateful for you taking the time.
    May 2015
    35
    Very interesting and helpful info here. I have been machining since 1990 and I am still learning so much. Thanks for taking the time.
  1. HELP! My new chuck's jaws are too big...
    By Plastictrojan in forum South Bend Machinery
    Last Post: 08-22-2014, 01:47 AM
  2. Replies: 8
    Last Post: 04-18-2014, 02:03 PM
  3. Truing chuck jaws
    By Vern Smith in forum Haas Lathes
    Last Post: 05-30-2010, 01:16 AM
  4. Chuck & Jaws
    By jdgromi in forum Uncategorised MetalWorking Machines
    Last Post: 01-30-2009, 12:48 AM
  5. milling chuck jaws
    By theatrewizard in forum Haas Mills
    Last Post: 02-28-2008, 05:09 PM
