586,795 active members*
2,606 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Puma 12s Help or Fanuc 0T
Results 1 to 7 of 7
    Dec 2015
    4
    We just purchased a used Daewoo puma 12s sn PS100715 with a Fanuc 0-T controller, Unfortunately we did not get any manuals with it.
    The machine was working and running parts before it was moved.
    Something seems to have happened during the moving process.
    On powering it up I get a 417 and a 427 error that are related to parameter. It appears there are no parameters in the Fanuc controller, when I scroll through the parameter pages they are all 0.
    Does anyone have a list of what the parameters are that need to be keyed in or any manuals for a Daewoo Puma 12s
    Thanks for your help and if anyone has any information please email to
    [email protected]
    thanks,
    marc
    Feb 2013
    788
    Re: Puma 12s Help or Fanuc 0T
    Is the "Blue Book" in the pocket, in the back of the electrical cabinet?
    If yes, all the parameters are there. (and specific to your machine)
    If not, give me the Model, control, and serial number...and I can locate a generic set that will get us started on recovery.
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Dec 2015
    4
    Thanks, I managed to get a copy from the mfg got it mostly running
    Feb 2013
    788
    Quote Originally Posted by marclm View Post
    I work for Doosan/Daewoo; is there anything I can assist with to get it past "mostly"...?
    Dec 2015
    4
    we got the machine running but it's not set in the final location
    so to power it up we ran it on temporary power but that was only 30 amps
    so I have seen most everything work but didn't want to overload the temporary service
    so it's hasn't actually run and made anything yet.
    I need to get a wall knocked down and get it set in it's final home and then get power to it.
    hence the mostly running, it's a work in progress.
    but I do appreciate the offer.
    Feb 2013
    788
    Please remember, when installing the power lines to check for a "wild leg" and (if it has one) to put the wild leg onto L2
    Dec 2015
    4
    thanks
  1. Puma 10S - Fanuc OT control
    By jaginst in forum FeatureCAM CAD/CAM
    Last Post: 04-16-2011, 06:12 PM
  2. Puma 450 Fanuc 18t
    By pumaman in forum Daewoo/Doosan
    Last Post: 02-20-2011, 10:26 PM
  3. puma 12l-b fanuc O-T
    By gmagnuson in forum Daewoo/Doosan
    Last Post: 04-11-2009, 10:06 PM
  4. Fanuc 0 & Puma 12L
    By Green Button in forum Daewoo/Doosan
    Last Post: 03-06-2007, 12:14 PM
  5. Puma 450 with fanuc 18t
    By The Puma Man in forum Daewoo/Doosan
    Last Post: 01-24-2006, 04:54 PM
