Though my CNC machine is a commercial one, an IronMan from Blurry Customs to be exact, I have serious orthogonality problems.
Attachment 301188
Unfortunately, this great looking model doesn't provide any means to adjust anything in a controlled fashion, no setscrews for micro adjustments, no pins of any kind, just bolts and slots which are useless in practice. The design as a table that is not directly connected to the X rails. If you prefer, this mean you could adjust one without affecting the other.
Attachment 301186
Using this tool above I have recorded a maximum deflection of 0.024" which is about 0.0576" per feet and it's not uniform across the table. Again, I have no practical mean to fix this. Maybe you dolt yourself guys have better ideas then mine.
You can assume I have the means to make each X axis rail leveled and planar and also I can make them parallel to each other.
Though I can check almost every thing else I have no mean to micro adjust anything in the current state.
Attachment 301190
Here is an idea of the method I`m considering now. It would allow me to raise or lower the gantry and even rotate it a bit, this on each side independently using the pink parts with the red setscrews at the bottom near the bearing. If I go all the way and add the green parts at top, I`ll be able to rotate the Y rails as a whole on each side independently. This allow me control orthogonality of the YZ the XZ and since I have 2 ballscrews driving the X axis it will be easy to achieve orthogonality of XY plane with YZ plane. I`m open ear to any other suggestion(s).
Unfortunately, I can`t use the tramming tool until I have all my axis orthogonal to each other. Thus ounce I`m done with the Y rails or axis I have to take care of the Z axis and here again I have basically nothing useful to make them orthogonal the other 2 axis. I haven`t given much thought to this axis yet. Suggestions please?
We still have make the table or the work plane if you prefer, parallel to the XY plane. That should be relatively easy now using a spoil board but at the expense of loosing access to the T slots.
Now, I hope you don`t expect the router mounting bracket to provide orthogonality on your first try, that would be like winning the lottery twice in a row. In case someone suggest using shims, I already know they work relatively well for rough alignment but for fine adjustment they`re useless. Even with setscrews it`s difficult, trust me I know.
I think I have an excellent understanding of what orthogonality mean and the kind of problems one will have if its machine axis are not orthogonal but I`m sure many of you have more experience in fixing this then I have.
Just in case, Alex Burt the guy from blurry customs, well he doesn`t seem to know what orthogonality mean to begin with.
Thanks for any help and or suggestion you could make,
Yves
