587,036 active members*
2,994 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Need help on Laser Firing in China Made laser Cutting Machine
Results 1 to 2 of 2
    Apr 2014
    4
    Hi, Have a problem on my 60w laser cutting machine. It is not firing well (about 50% output). I previously used to cut 6mm acrylic with no problems but now i cant cut though 5mm acrylic.
    I have already
    - Clean the mirror and Lens
    - Realign and calibration on the cutter.
    - Change the cooling water and even try to use chlorine to cleanout the tubes.
    Attached is the tube when firing ->
    Firing is consistance but output power is lessen by 1/2. Just wondering if it is power supply problem or tube problem. Anyone can advice? Thanks.
    Jan 2008
    940
    Re: Need help on Laser Firing in China Made laser Cutting Machine
    On your meter how many MA is showing. Is your air assist working. focal point set correct
  1. China laser started firing laser during rapid moves
    By Billn in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-21-2016, 06:32 AM
  2. china cheapest 1390 laser cutting machine storm1390
    By wklaserliu in forum News Announcements
    Last Post: 01-24-2015, 08:37 AM
  3. China CS4040 Mini. Laser Engraving Cutting Machine
    By lucylucky in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-01-2014, 11:42 AM
  4. Laser engraving machine not firing laser from software or controller.
    By JustTruckinng in forum Engraving Machines
    Last Post: 05-14-2014, 04:14 AM
