586,655 active members*
2,314 visitors online*
Results 1 to 19 of 19
    Aug 2013
    980
    Working with brass
    I have almost exclusively worked with 6000 series aluminum and now a client wants me to make his parts and
    In brass.
    I will probably be using mostly free matching brass and architectural brass.
    For those of you who machine brass, is there anything I should know? The material is really expensive but it seems like I should be able to machine it like aluminum.
    Nathan
    May 2015
    111
    Working with brass
    I have worked a little with free brass. It does machine like aluminum but the finish is much nicer. I used tha same carbide endmills that I use on aluminum. I did run a little slower Sfm.
    7063
    Re: Working with brass
    Brass is much like aluminum, though it depends a lot on the specific alloy - some are quite hard. I'd start at 50% of the 6061 feed, and see how it goes, and speed up from there. If it's truly free-machining, you should be able to get close to the 6061 feeds. Brass generally will not create strings when drilling, which is nice. For free-machining brass, HSS tools will work well.
    Ray L.
    Jun 2006
    340
    Machine brass dry.
    Aug 2013
    980
    Ray L.
    Aug 2013
    980
    Really? I was going to use flood colonist like I do with aluminum. I saw a job shop machining brass once and they were using coolant.
    Quote Originally Posted by bevinp View Post
    Machine brass dry.
    Aug 2013
    980
    That is what I was hoping to hear.
    Quote Originally Posted by cbyrd View Post
    Mar 2009
    1863
    360 brass is a free machining material.
    I do a lot of work with brass, and it cuts just like aluminum.
    AND I ALWAYS USE CARBIDE.
    Just be sure your brass chips don't get mixed with your aluminum because that will make your aluminum chips worthless.
    I use HSS drills, taps and reamers, but end mills are ALWAYS carbide.
    Aug 2009
    610
    Ran naval brass here for a project (lead free) on my 770 a few years back. It cuts pretty well, but was harder than I had anticipated. I had turned a lot of brass on a lathe, but hadn't milled much of it. It is similar to 6061 T6, but a little stouter. Fed at 23.5 IPM and RPM was 6580. I used mist coolant and a 3/8" 3 flute carbide end mill stuck out 1.25" from a set screw holder. According to the program notes I ran DOC 0.125 WOC 0.175. and plunged at 5IPM. Hope that this helps you.
    Aug 2009
    610
    Oh yeah and climb mill for the best finish. It's a very aesthetically pleasing material.
    Aug 2013
    980
    Did you use flood?
    Quote Originally Posted by Steve Seebold View Post
    Jun 2006
    340
    Quote Originally Posted by CadRhino View Post
    Machinery's Handbook says dry, as do many googled hits. It was what I was taught about 40 years ago, but things may have changed. Search on the site of the manufacturer of the cutters you will use and get their advice. .
    Jun 2006
    3063
    I've machined a few brass parts with my 1100 and machine dry with a small air blast, essentially the Fog Buster with coolant turned off. Seems to work well for me.
    Aug 2013
    980
    Ok thanks
    Quote Originally Posted by MichaelHenry View Post
    Aug 2013
    980
    Thanks for the insight.
    Quote Originally Posted by pickled View Post
    Jul 2007
    1602
    Some grades of brass are very "grabby" so you have to be mindful of that. While not as much of an issue on a CNC as on a drill press, it can be especially bad when a drill cuts through the back side. Thin stock could flex enough to be pulled out of a vise.
    bob
    Jun 2014
    1780
    Quote Originally Posted by rowbare View Post
    bob
    Straight flute drills are what I use for brass, a twist drill will work well too if the gullet rake is ground straight at the tip, this also works for any thin material or plastics. Positive rake tools do not work well drilling brass.
    mike sr
    Aug 2013
    980
    Great, thanks
    Quote Originally Posted by popspipes View Post
    Jun 2014
    1780
    I have turned brass on the lathe occasionally, but all my lathe tools have a 90 degree top rake and its not a problem.
    mike sr
  1. What is the difference between wood working and metal working routers?
    By LaughingJaguar in forum Joes CNC Model 2006
    Last Post: 10-17-2016, 07:29 PM
  2. Working with brass
    By CadRhino in forum Tormach Personal CNC Mill
    Last Post: 11-29-2015, 05:29 AM
  3. Switch view between machine working enveloppe and job not working?
    By skillalot in forum Screen Layouts, Post Processors & Misc
    Last Post: 08-10-2015, 03:55 PM
  4. Replies: 10
    Last Post: 01-16-2013, 06:52 AM
  5. Weld Brass to Brass
    By piratesover40 in forum Welding Brazing Soldering Sealing
    Last Post: 03-04-2008, 01:02 AM
