We have recently picked up a Multicam PRO (10'x5') machine and it seems really nice ...
Everything works, it references fine and can be jogged etc etc ... except ... the serial cable.
There was at some time a 25 way D type connector on the side of the machine .. all that is left is a cut cable that goes back to the controller card, where it terminats in an RJ45
The machine is older .. so I think it is unlikley it is ethernet ... we have the full wiring diagrams, but, for soem reason, this cable was not documented on our machine.
Multicam were kinda helpful, but did not seem to have any info beyond sending a PDF of the same diagrams we already have
if anyone out there has an older PRO machine with the Extratech M23 interface boards, and could take a photo of the back of the 25way D type, on the side of the machine, that would probably solve our issues. The RJ45 end is wired in "standard" order, so a photo of the back of the 25way D type so we can see the colour codes fo the wires would allow us to work it out.
much appreciated if anyone can help.
