I have a 140lb table 622 Newtons and have played with some online calculators and can't seem to get a definitive answer on torque and of what I should expect.
Right now I have a 2.5hp 4000 rpm Brushless servo driving a THK C5 ball screw 2520
Ball screw diameter is 25mm
Lead is 20mm
spec sheet says .05 efficiency (I think I'm reading that right)online calculators say use 90% for rough estimate
I'm trying to figure out is if I should have gone with a 2505 ball screw instead
Ball screw diamter of 25
Lead 5mm
This is load is a 30"x30" x.5 in Steel plate for the bed of my CNC machine.
What kind of rapids can I expect out of this machine?
What kind of torque can I expect of of this machine?
What kind of accelerations can I expect out of this machine?
Thanks in advance.
