587,036 active members*
2,941 visitors online*
IndustryArena Forum > CAM Software > SheetCam > No Code Option in Path Rules
    May 2013
    53
    I have built my own 4'x4" table using CandCNC BladeRunner Dragon Cut 620-4 EtherCut + DTHCIV.
    Still in the teething stages but decided to play with the path rules in Sheetcam and I have run into a problem. There are no code options to insert?
    Screen shot:
    Using CandCNC post
    DTHC-HYT-TAP_SoftPierce+Marker-rev11J.scpost
    Any ideas?
    May 2013
    53
    Re: No Code Option in Path Rules
    Solved this problem. In case anyone is searching and has this issue:
    There should be code snippets listed in the tool table. Just create them as needed and then they will be in the drop down menu of path rules.
    Sep 2015
    29
    Quote Originally Posted by Eric S View Post
    Hey Eric, I am trying to create rules also.. more so to fix my hole quality on small holes and circles. > my plan is to create rule to slow speed to 60% and turn off THC when cutting, so the torch doesn't dive when the speed is slowed.
    How did you figure out what "code" commands what when making the code snippets?
    thanks
    May 2013
    53
    I used this manual. It is labeled for DTHCII but seemed to be the same for DTHC IV,
    http://candcnc.com/images/Manuals/DT...ConnectDCC.pdf
    Jul 2005
    2415
    Quote Originally Posted by snowdaze View Post
    thanks
    If you are using a leter post (11J or higher) there is a "min Cut length for DTHC" box in the Operations. Simply set it to greater than the largest hole circumference + lead in. For speed control group all of you holes on a new layer and change the feedrate. and build an opeaartion with that new layer. Depending on the DTHC modle you can get duelling DTHC ON/OFF commands with too many rules or in the wrong place. There is a specific manual for the DTHC IV on the website in the Manuals page. There is a section on using rules and som eof the other custom features and how to write a code snip to use in a rule.
    TOMcaudle
    www.candcnc.com
  1. No DTHC options under path rules
    By Autoprosoffroad in forum SheetCam
    Last Post: 09-07-2014, 05:01 PM
  2. G-Code option on Motion Controller
    By TRMInt in forum News Announcements
    Last Post: 06-13-2012, 04:38 PM
  3. Mitsu code for option 38
    By Barman79 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-18-2011, 04:09 PM
  4. Fanuc 18T option code help
    By mikeyson in forum Fanuc
    Last Post: 10-13-2008, 01:01 PM
