Re: HSD 915 tool change spindle air usage
It does not need air 24/7. I turn off my compressor when I leave in the evening - sometimes minutes after I finish routing - and I've even run the CNC on just the tank air for a while when I forgot it was turned off due to the forklift charging on the same outlet (eventually the tool change stops working and you figure it out) and it seems none the worse for wear though I am not the busiest router around.
In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
