Hi ! i'm just bought a laser machine, with a CO2 Laser tube 60 W, and need to cut pieces of wood about 5mm thick , the problem is that the laser does not cut , I'm working with RDWorks for the design and control of the machine, i don't know what's wrong, my friend said that the tube probably does not have enough power to cut (60 w ) I attached some images of the cutting configuration to see if is this the problem..
