I'm routing MDF raised panel doors. I've been stumped, so I figured I'd try here.
I'm using 4 tools -- a .500" compression bit to clear the central channel, a wide V to create the inner raised panel, and an ogee to create the outer channel profile, cleaning up the corners on the outer with a .125" downshear.
My methodology so far is to create 5 offset rectangles, constrain by center distances (of tool), and place each on a different layer. I then assign my User Tools based on the layer in Machning Styles, and finally save it as a "block" (in the CAD world) to insert into whatever geometry I'd like the rectangular panel to fit in.
Obviously this works well, and saves time once the initial constraints are defined. However, this seems like too much work.
I'm hampered by lack of a real technical ACAM manual....but I don't have access to one, so figured I'd try here.
What I'd LIKE to do, is define a single profile path, then send all 4 tools down the path at different offsets, rendering the correct geometry of cut for a raised panel. I'd like to make it a single (or couple) click operation. So, the real question is how to save a "machining style" that incorporates offsets for tool tips....
Thoughts? Or do you all do it like I did...
I did reason a "hack" -- if I defined each tool width as double the required offset, and told it to follow "inside" instead of "on center", they'd all chase each other in the correct orientation, but that would involve misdefining them on my controller or in ACAM, and I'm not sure that's a wise machining practice... I'll resort to it if I have to.
Appreciate any assistance. ACAM v8 doesn't seem to offer some things that seem pretty basic, or perhaps I'm just missing it.... Lemme' know.
Cheers,
~Ted
